I would like to be able to store different settings. I am using a 3Dconnexion wireless spacemouse in solidworks where i like to use it whith the motions reversed and a slow speed while a collegue of mine likes it with a higher speed and not reversed. Now i was wondering whether is would be possible to store this profiles and use one of the options on the buttons on the side to switch profiles. Would like to hear from you.
Kind regards,
Albertoo
Different setting
Re: Different setting
Hello Albertoo,
currently you cannot have two configurations at the same time and switch between them. The only way would be to stop the driver and replace the configuration files and the restart the driver. But this is not what you want.
Thanks for the reply. Any clue on whether this is a feature that might be implemented in the future?
You are both using the same account?
