Space Navigator 3d mouse to work as MIDI
KonstantinosF
Post by KonstantinosF »
Hi there, I have the Space Navigator 3d mouse and I am looking to use it also as MIDI controller except of CAD navigation. I have found this site
with a driver RBC9, the VST 3DMIDIGator and tutorial how to install:
https://www.3amnoise.net/runagate/Space ... su2iWGuYUw
I followed the instructions, I installed the driver and the VST, all open but does not work. I must have done something not right with driver installation because when I open the RBC9 program it says: RBC9 Space driver - ! Space navigator not found !.
Anyone can help with more detailed instructions how to install the driver?
Also in the tutorial it says first I need to de-activate the 3d-Connection driver to install the RBC9 driver but I can not find how.
Finally I want to express my wish for an official driver for using Space navigator - 3d mouse as MIDI controller.
Phil999
Re: Space Navigator 3d mouse to work as MIDI
Post by Phil999 »
to stop the driver, there should be an entry in the 3Dconnexion Start Menu, 'Stop 3DxWare'. Maybe it works after that.
I think you should be able to use the joystick mode of the 3DxWinCore driver in place of the RBC9 driver. IIRC, he converted the 3D mouse data into joystick data. The driver can now do that.
Is there src available for this 3DxMIDIGator.dll?
I'd like to add MIDI output to the 3DxWinCore driver, but I don't have a clue what it looks like (but bits are bits).
A few people have done their own implementations with interesting results.
Phil999
Post by Phil999 »
I also think that using the official driver with joystick mode, together with a Joystick-MIDI converter, is the better option.
I think that I used RBC9 for a while, and Space Navigator as MIDI controller, but I don't remember anymore. I don't think the Space Navigator is a good MIDI controller anyway. A real joystick (for flight sims) is better in my opinion, easier to configure. For some years I used a simple passive joystick (one that doesn't have springs) together with a Doepfer Drehbank controller to perform quad panning in Cubase. Which I then soon replaced with tablet MIDI controller apps (TouchOSC, Lemur, Konkreet Performer, TC-Data, etc.) in 2012, which are much more versatile and easy to setup.
KonstantinosF
Thanks for the answers! I will see again soon what I can do to setup it and make it work and the solutions you suggest. I am interested for this and not for a regular flight-simulation joystick because I can have 6 axis in one hand. I am also interested if I can develop in the future something similar with even more parameters to control for use in music or any other application, for now I do not have the knowledge for this, just some ideas springing in my head.
acoufhaine
Post by acoufhaine »
Hello !
Have you find any option to make it worl as surround panner midi remote in 2020 ?
I would like to do it with cubase 10 / Windows 10 64bit with binaural panner (who need 6 axis)
Thanks for help !
Best !
chason
Post by chason »
I created an account just to +1 and to volunteer to assist with this project. I'm a long time musician and programmer, I've done work with MIDI before https://github.com/ChasonDeshotel/Reloop-RP-8000-MIDI
I've been drooling over the SpaceMouse Pro since I've seen it but if it can't natively be used as a control surface inside of a Digital Audio Workstation (DAW) then it's a hard sale
If you implemented MIDI and sent out the Mackie control surface map as a default mapping, it'd be the most compatible and this is what other manufacturer's do (e.g. Icon Pro control surfaces). That ensures it'll work in any major DAW. http://www.jjlee.com/qlab/Mackie%20Cont ... %20Map.pdf
I've considered getting one and hacking it up.. make all of the connections to an Arduino. For someone with a small desk this looks like the ideal control/transport surface
I would also want keyboard shortcuts on some of the buttons still but I could totally live without that if it meant MIDI
Will sign NDA. Happy to contribute, test, and/or advise
Is there source or are these reverse engineered?
Hi chason,
There has always been some interest in MIDI control but I know nothing about it. Perhaps you can help me to understand the structure. I assume the 3D mouse needs to act like a MIDI device. It's not possible to change the actual USB output (HID MultiAxis Device packets), but it is possible to remap it.
It seems like a natural fit, having 6-12 high res analog of controls in one hand. It might not work out as well as it sounds. The values (axes) are not independent. They are sensed and sent independently but they are all sensed at once. It's nearly impossible to activate one axis w/o also inadvertently activating another axis. It's possible, and likely, that software filtering would be required to eliminate undesirable crosstalk.
The axes are also spatially mapped. It really only makes sense if there is some physical mapping between what you are doing with your hand to the result. E.g., moving left vs right could change the balance from left to right, if possible. Otherwise, it's difficult to predict what will happen, what relationship there is between all the controls. You might find that it is only useful one degree of freedom at a time-a giant jog wheel. Albeit a high resolution wheel.
The Windows driver can output any data. In the can, it outputs 3D mouse, Joystick, Keyboard and 2D mouse data, but it is extensible.
I think most of the people who have this working are having it output joystick data that another piece of software imports and converts to MIDI (maybe the DAW itself does this).
I'm not sure that is ideal, but the conversion software probably contains relevant GUI controls that are way beyond the scope of our GUI. Maybe the DAW takes on this task. I assume there is some mechanism for connecting a physical device output to a DAW virtual control input. (I've never seen a DAW).
There does seem to be quite a variety of patching software available with MIDI-specific options that are useful. Maybe there is one that takes HID output and converts it to MIDI device output. I wouldn't be surprised if some of the DAWs did this.
I'd be happy to work with you to develop something that supports the MIDI community. Having a range of potentially inter-related high res axes for input and warping seems like an interesting application of the 3D mouse.
Jim
coaster
Post by coaster »
Greetings, Another engineer here. I am interesting in implementing this feature for my homemade synth. Start a Github project please, so we can contribute to official 3dconnexion stuff. Do not force us to sign NDA. Instead create a contributors markdown file that establishes expectations for us that seek MIDI and spacemouse. Best regards, Coast
lokey
Post by lokey »
hi folks! i've got a m4l patch that i use in ableton live to convert the cmj joystick input from a spacenavigator into midi messages, which in turn get sent to another m4l patch that maps the cc's to various controls.
happy to chat about what it's doing with anyone, there's a lot of usage decisions i'm making here for my own rig that might not suit yours, but for anyone using ableton, you're welcome to use this:
here's the spacenavigator patch
https://www.dropbox.com/s/x5zfxjd6tjlzh ... .amxd?dl=0
and the cc mapper
https://www.dropbox.com/s/fqzitfy1cohk7 ... .amxd?dl=0
Phil999
Post by Phil999 »
thanks. I am not an Ableton Live user, but it's good to hear about conversions of non-MIDI devices to MIDI commands.
sveinbjorn
Post by sveinbjorn »
lokey wrote: Mon Nov 08, 2021 5:49 pm hi folks! i've got a m4l patch that i use in ableton live to convert the cmj joystick input from a spacenavigator into midi messages, which in turn get sent to another m4l patch that maps the cc's to various controls.
and the cc mapper
Hi lokey! Just downloaded these, can't get them to work. I opened the thing in Max (although I have no idea how anything works there), got this error message: "hi: hi: Tetherscript Virtual Joystick is not a valid device name"
Do you have any idea what's going on there?
I also couldn't figure out the Expression Control device. If it wasn't recieving any midi, that's probably normal. But the usual MAP buttons aren't there and then I'm stumped :)
Sv.
Schlex
Post by Schlex »
Hi folks,
great to hear that you plan an implementation of 3D Mouse to DAW. Navigating in Nuendo could ge much easier with this device, for zoom an scrubbing the timeline. Im longing to see your solution.
Schlex
darkwhite
Post by darkwhite »
jwick wrote: Mon Mar 15, 2021 2:09 am It's nearly impossible to activate one axis w/o also inadvertently activating another axis. It's possible, and likely, that software filtering would be required to eliminate undesirable crosstalk.
some thread inspiration for 2022 :)
Exact control is not necessarily required for musical applications, like Expressive E's Touche device: https://www.youtube.com/watch?v=sZpZYTSClgY.
Maybe just rate-limiting, mapped to a couple of preset curves.
For Raspberry Pi/Linux this looks like a technical, but standalone solution: https://github.com/gethiox/HIDI
Thalamus
Post by Thalamus »
and the cc mapper
This is music to my ears. I'm an Ableton Live user and happen to have a spacemouse that I'd love to use to control aspects of the DAW. Fantastic. I will try this ASAP. Do I need to install the 3dconnexion software for this to work?
