I just have connected a Spacemouse to Rhino for Mac for the very first time.
I have now figured out how to map all buttons on the SpaceMouse (simply create command keyboard shortcuts within Rhino, then map these keystrokes to the buttons of the SpaceMouse within the SpaceMouse preference menu profile for Rhino).
Mac Rhino and Spacemouse Pro
Re: Mac Rhino and Spacemouse Pro
The movement of the model does work beautifully.
One small issue I found though is this: vidmate save insta
When designing in isometric view, I tend often to use parallel projection view rather than the standard perspective projection
crossvid,
What are your OS X and Rhino versions? I am running OS X 11.6.1 and Rhino 7 with a Space Mouse Compact. The 3dconnexion settings in Rhino 7 Preferences override anything I set in Mac System Preferences. I'm trying to set one of my buttons as just Command + Shift (to pick subD faces and edges) and I cannot figure out how to describe that keystroke in Rhino preferences. Using the actual symbols produces nothing (⇧⌘).
