Spaceball4000FLX Serial and spaceNavigator on same computer
vogtbran
Post by vogtbran » Wed Apr 04, 2007 9:58 am
I am currently using a SpaceBall - serial port connection at work and I just bought a SpaceNavigator. I installed the new software and the SpaceNavigator worked but my SpaceBall did not. I uninstalled the new software and installed the old v2-8-2 software and my SpaceBall is working again. What will happen when I plug my SpaceNavigator into my computer? Can I switch back and forth between these 2 products?
FYI - I am not trying to run these products at the same time.
Post by jwick » Wed Apr 04, 2007 10:12 am
Hi vogtbran,
Unfortunately you perfectly timed the crossroads between device support. 2.8.2 was done before the SpaceNavigator was anything more than a dream, so it doesn't support the SN.
OTOH, 3.x which does support the SN, doesn't support serial devices.
The only solution is to do the uninstall/install procedure that you are doing.
3Dx Software Development
