help my space navigator has a skin disease....... serious!
yamlcase
Re: help my space navigator has a skin disease....... seriou
Post by yamlcase » Mon Jun 12, 2017 6:34 am
Easy-Off did the trick for me. Just spray it thick into a paper tower, hold the navigator upside down and cake the Easy-Off foam on the knob and buttons. Set it upside down for a few minutes, then rub the gunk off. Throughout this, always keep the navigator upside down so if anything drips it will not get into the innards. Also, ventilation. This stuff stinks and is probably not good for you.
Natty
Post by Natty » Tue Oct 17, 2017 11:22 am
I do have the exact same problem.. And it feels disgusting.. I've tried to clean it, but with no use. The degrading rubber is something that you should not have to worry when you spend 300€ on a piece of electronic. I don't even remember when i've bought mine to know if it is still under warranty.. But this is very sad, that you would spend that much money and end up with a 2$ rubber cover.
matteolegna
Post by matteolegna » Sat Oct 21, 2017 3:52 am
I just feel the need of adding my voice to the choir. I'm also experiencing the same issue on my SpaceMouse Pro purchased in December 2012
mhoopes
Post by mhoopes » Fri Nov 03, 2017 12:47 pm
SpaceNavigator, purchased in 2008. Retired in 2016.
Michael Hoopes
razyr
Re: help my space navigator has a skin disease....... serious!
Post by razyr » Tue Nov 28, 2017 6:49 pm
My Space Navigator looked pretty much like the image posted by mhoopes.
I've run across this on multiple items with rubber or synth rubber materials which break down with age. I've seen it with ski boots, wet suits for diving and now 3D mice.
The friction coat is extremely thin and is easy to remove if you have a secret weapon.
The surface is gummy and attempting to scrape it off with your fingernail just pushes it around and smears it.
My go-to trick for removing gummy labels on plastic or metal is WD-40. Spray a bit on a 3M abrasive pad like you'd have in your kitchen. Obviously the pad isn't going back to the kitchen when you're done. Use your fingernail to loosen thick or stubborn areas but the WD-40 prevents the goop from re-sticking itself or smearing and it helps lift it off the Space Navigator knob.
This method doesn't produce any dust (like trying to sand it) and if you don't go crazy with how much WD-40 you spray on the pad, you don't have to worry about anything getting inside your mouse.
It took maybe 15 minutes to clean my 3D navigator up to near-new condition. It's not quite as nice as the original friction surface but neither does it feel like you grabbed the wrong side of an old sticky bandaid. It looks like new again and it's actually easier to keep clean.
steph-tux
Post by steph-tux » Wed Jan 17, 2018 11:32 am
I had the same problem with my SpacePilot (mouse and pad very sticky).
In fact, the solution is very easy !
I bought a 1 liter bottle of 95° alcool (in french : alcool ménager supérieur à 95°), that you can find very easily for 2 or 3 €.
Then, put alcool on a soft cloth, and wipe all sticky parts of the space mouse.
You will have to change many times the soft cloth (it becomes dirty very quikly).
At the end, there will be no more "sticky skin" on your mouse.
You will lose the soft touch feeling, but it's ok, and no more sticky !
michaeld
Post by michaeld » Fri Jan 26, 2018 2:06 pm
I got tired of the rubber always becoming a mess so scrubbed it off with some GoJo Cleaner. After the grit dried I air blasted it off and I was left with a nice smooth plastic.
Old Space Explorer, works good as new.
Keerah
Post by Keerah » Fri Jan 26, 2018 5:59 pm
My space navigator is just 1+ year in use and first the surface had bubbles in it and now it has "bald" islands of the coating, doesn't look and feel nice, it's very disappointing :cry: There's no extreme weather in my appartments
Post by UtaSH » Mon Jan 29, 2018 3:17 am
Hello Keerah,
this should definitely NOT happen. If the device is just one year old it is still under warranty. Please contact our Technical Support Team. They will start the RMA process for you.
Delarmi
Post by Delarmi » Wed Sep 19, 2018 10:57 pm
A while ago, I wondered why my space navigator is so dirty and sticky... Are my fingers really sooo dirty...? I started to clean it... my charwoman came to help me, but we both did not manage to clean it. Now my space navigator looks really really shitty and sticky sticky sticky...
And today I found this topic ... :evil:
So, can I get a new space navigator, please? :roll: :mrgreen:
I bought it 2013... thank you
dlkeener
Post by dlkeener » Thu Oct 18, 2018 6:39 am
Space Navigator has that sticky feeling and peeling, has for a few years.
currently am using a new wireless version.
The other is my personal navigator, just sits in a box being sticky.
last I used it was fine, then boxed it up, after a few years, took it out, sticky.
Started peeling about 3 years after I had it.
Can't work with out a Navigator...great device.
Mine is was purchased about 2005, give or take a few years.
might try the dipping thing, needs something, i've retired it to my home computer.
jones814
Post by jones814 » Sat Nov 17, 2018 9:49 am
As a last resort, try baby powder. Imagine putting baby powder on duct tape. It stops being sticky. Over the years, I have had several electronic gadgets that were designed with a cool rubbery surface that years later became a gross sticky surface. I put baby powder on the surface, brushed away the excess, and it occupied all those sticky molecules with something to stick to.
MutterOberin
Post by MutterOberin » Thu Jan 24, 2019 10:08 am
I have the exact same problem with a space pilot! Hopefully the space pilot pro will not have the same issue in the future!
protorixx
Post by protorixx » Thu Jan 24, 2019 10:24 am
You can use oven cleaner to remove the soft painting of the knob
pintom
Post by pintom » Thu Jun 13, 2019 10:10 am
Why the hell does 3D Connexion still use this rubber coating on these expensive input devices!?! It's like they completely ignore their customers' complaints about it and keep putting this "cool" rubber coating on all of their products! Yeah it looks cool and feels cool for about a year then it becomes a sticky mess!!! Please Stop doing this!!!!!!!
3dconnexion Hardware: SpaceMouse Pro USB, CADMouse
Computer: HP ZBook Studio G3
OS: Windows 10 Pro
