Hello! We have an application written using the 1.8.0 Linux SDK. We are having an issue in which our application stops receiving events depending on what window is in focus. I have searched through several posts and have seen related issues, but either I don't understand the solutions or they don't apply to our situation.
The most straightforward solution for me would be to set the "Hard Grab" behavior as mentioned in this post for Windows development:
https://www.3dconnexion.com/forum/viewtopic.php?t=36563
One of the options is to edit the .xml config file to set the Grab to Hard. However, in Linux, there are .scg files instead of .xml - Is there a similar solution for Linux development?
Hard Grab
Re: Hard Grab
Thank you so much! Yes, we looked into that and it was very helpful. Thanks again, I will close this topic.
