Bug: Click and 3D space mouse don't work after restart
rjtiedeman
Re: Bug: Click and 3D space mouse don't work after restart
Post by rjtiedeman » Sat Jan 26, 2019 8:54 am
Questions:
1. Is this a new mac issue or a Mojave issue?
2. Would turrning off SIP (System Integrity Protection) before installing 3DxWare help or not?
3. Since we just got 10.6.1. Will the 3DxWare upgrade fix be 6 monts or a year?
NOTE: The 3Dconnection Universal Receiver will not PAIR if connected to my TS3 PLUS USB docking station. The unplug / reinsert workaround only works when plugged directly into the Imac Pro USB ports. WILL NOT PAIR with external USB Dock.
Yes this is an inconvenience.
Rjtiedeman
marcarch
Post by marcarch » Wed Feb 06, 2019 3:13 am
1. This is a Universal Receiver driver bug, nothing more
2. I didn’t try this, and I won’t. I'm not messing up with the OS for a driver incompatibility bug.
3. I reported this bug back on the 22th of October 2018, I’ve been waiting nearly 4 months for a fix, we're quite there (for the 6 months)
- I’m quite sure you have a double driver incompatibility with macOS: universal receiver one and the usb dock driver too.
I use to unplug-plug the universal receiver with my external monitor (that is an usb hub too) and it pairs.
Yes. This is a big inconvenience. Can’t understand why is taking so long to fix.
cologneled
Post by cologneled » Thu Feb 07, 2019 5:16 am
The only way to get the iMac Pro to recognize the 3D space mouse after restart is to pull the wireless receiver and reinsert it.
maggi_magnum
Post by maggi_magnum » Sat Feb 09, 2019 11:38 am
Is this bug fixed in driver 10.6.1??
omnikurt
Post by omnikurt » Thu Feb 14, 2019 7:43 am
I have the same problem with a USB connected Space Navigator on Mojave. Works fine as long as I unplug and replug the device after every reboot. Really a nuisance. Please update/fix the driver. I'm on OS 10.14.3 with the latest driver.
maggi_magnum
Post by maggi_magnum » Fri Feb 15, 2019 5:36 am
Installed driver 10.6.1..... vola everything works fine. Thanks guys. :D
marcarch
Post by marcarch » Tue Feb 19, 2019 5:52 am
Are you sure? I'm with driver 10.6.1 and the bug definitely persists.
summer
Post by summer » Wed Jul 31, 2019 5:27 am
I have the same problem with 10.6.3 drivers.
Post by UtaSH » Fri Aug 02, 2019 7:40 am
Hi summer,
please make sure you disconnect all 3Dconnexion devices and then try to allow the kernel extension (after you rebooted).
