New Spacemouse Wireless not working correctly
Re: New Spacemouse Wireless not working correctly
Post by UtaSH » Wed Aug 22, 2018 8:45 am
Hi danshaw19,
do you have a SpaceMouse Wireless?
What is the version of the installed driver?
Did you enable the kernel extension as requested in FAQ #1127?
Did you test the 3D mouse with the 3Dconnexion Viewer?
Which application do you want to use the device with?
marckitect
Post by marckitect » Thu Aug 23, 2018 11:01 pm
I have the same problem.
I have a SpaceMouse wireless. The installed version is 10.5.3. The kernel extension was enabled as prompted at installation as per faq 1127. The mouse was tested with the viewer and nothing happened except that the geometry was highlighted. I intend to use the mouse with Sketchup Pro, but no configuration has been attempted since the tool window says that no device is found. The extension in About this Mac says that it is NOT loaded. I am using OS 10.13.6.
How do I reload correctly?
perryf
Post by perryf » Tue Aug 28, 2018 11:01 am
Hi I am having the same issue, I have checked the System Information and looked in software and it is present but not 'loaded' ? What can I do to resolve this issue?
marckitect
Post by marckitect » Tue Aug 28, 2018 5:01 pm
I answered my own unposted reply saying I have the same problem after installing the driver and permitting the kern to install at the prompt. My solution was similar to one posted but not completely. It may be the difference between different OS updates. I am running OS 10.13.6 High Sierra.
Go to System Preferences and open "Security & Privacy".
Partway down, identify "Some system software blocked from loading".
Click on the "Allow..." button.
Scroll through blocked software list. Check the box for 3D Connexion.
Click "OK".
Restart.
After logging in, check the Extensions menu in the Software Systems Report of "About this Mac".
The "Loaded" status for 3D Connexion should now say "yes".
My SpaceMouse is now working and I am delighted with early results. I look forward to learning its capabilities.
Post by UtaSH » Wed Aug 29, 2018 2:29 am
Please contact our Technical Support Team.
perryf
Post by perryf » Wed Aug 29, 2018 2:42 am
Already contacted them, vague non helpful response!
Sadly sent the item back for refund as now it is also making my system crash due to memory leak when using SketchUp!!
Very poor software/driver has ruined what looked like a very good piece of kit!
maz3d
Post by maz3d » Wed Aug 29, 2018 7:40 am
Just wanted to let everyone know that I had the same issue and there was a simple fix.
I was trying to use SpaceMouse Pro on my Mac (High Sierra - 10.13) with 3dWare10 (10.5.3).
Having installed the spacemouse driver and overcome security issue by allowing the extension to run, I thought everything was good to go..
But it just didn't work and the mouse wasn't found in 3dWare10 despite showing up in the USB devices list. I was able to move the cursor and click but nothing else.
How did I solve the issue? I uninstalled 3dWare10 - 10.5.3 and installed earlier version 10.4.4. Worked like a charm!!
