Error: 1618
awarren
Error: 1618
Post by awarren »
I was trying to upgrade to the new version and I got an error saying it had aborted. Then I tried to download it and install the exe and I get Error: 1618. Anyone have any ideas what is going on?
Andrew Warren
Software Consultant
Middle TN, Southern KY Autodesk Users Group
awarren
Still going
Post by awarren »
I re-downloaded it and still get the same error... Should I try an un-install / re-install? I am afraid it will kill my Pilot all together...
BTW
XP SP3
Gateway Laptop
Nvidia Geforce GO 7900 GS
2 Gig Ram
2.16 Duel Core II Duo Intel
AutoCAD, Invnetor, Solidworks, SolidEdge,
Andrew Warren
Software Consultant
MSI Error 1618 is: there are two installs running at the same time.
Do a clean uninstall, reboot and reinstall.
awarren
Error: 1618 Again
Post by awarren »
jwick wrote:MSI Error 1618 is: there are two installs running at the same time.
I uninstalled everything, went into the registry and removed all 3Dx related keys. Restarted twice and did a fresh download of the newest version. G
GOT THE SAME ERROR! Now I do not have any drivers loaded, please help!!!
Andrew Warren
Software Consultant
Peter
Post by Peter »
Dear Awarren,
Do a clean uninstall (from the registry) again and then reboot the PC.
Download (from the Microsoft website) the Windows Installer Clean Up Utility and install same.
Run the utility and delete any instances of 3d connexion/3dx ware.
Install the 3dx driver that you had previously downloaded.
Peter
Hi Warren,
If you see "empty" items listed on the "Windows Installer Clean Up Utility" panel, remove those as well.
awarren
Just an FYI
Post by awarren »
Striker is a 3rd party dev for Autodesk add-ons, and a resellers for 3Dx. This is not my first time removing software. It was gone trust me... What else can be hanging? Do you have some kind of reg key hidden under another name?
Andrew Warren
Software Consultant
Re: Just an FYI
awarren wrote:What else can be hanging? Do you have some kind of reg key hidden under another name?
The files may have been removed but the database of Windows Installer may be corrupted. Using the "Windows Installer Clean Up Utility" as explained above should help clear that up. The tool can be downloaded from the Microsoft web site here.
awarren
Error: 1612 Now???
Post by awarren »
What else you got? New error does this mean anything?
Andrew Warren
Software Consultant
awarren
Got it
Post by awarren »
I finally just backed up my registry and removed every installer that I was unsure what it was (mainly all the numbered ones) and that seemed to fix it I think. It installed at that point, not sure what else it is going to effect but my controller is working again.
Andrew Warren
Software Consultant
