The use of Visual C++ 2005 Express Edition is a problem??
Because of the error of compilation me seems that the problem is in the librarys "atlcom.h and atlwin.h", not in the version do Visual Studio...
Anyone have any idea?
Thanks.
space Navigator and openScenceGraph application
Hi mony84,
Ok. I have VRPN (although it has not yet used). A few days ago, I tried to download a version of osgVRPN. I did not find a link right to it, much less usage instructions. You could pass me some details?
If possible, I would like to see your code. Thus, it could try to adapt to my case ... you could help me?
Thank you.
Thank you.
Hi rodrigo.seabra,
Finally, I didn't use VRPN. I get help from the osg mailing list. (I would like to say thank you very much).
main ()
// init
// osg inits ..
SbInit ()//connect to the spacenavigator
// main loop
while (!viewer.done())
// DispatchLoop is similar to the sdk example but instead of
// while (GetMessage (&msg, NULL, 0, 0)) -- original
// use this:
// if (PeekMessage (&msg, NULL, 0,0,PM_REMOVE)) -- otherwise it blocks your main loop
DispatchLoop()
if (Spw_Redraw)
setViewMatrix(....) // position and rotation from 3dConnexion
Spw_Redraw = false
viewer.frame()
[code]
Dipatch loop is the message loop.
You can use either the cityfly example or the cube3Dpolling example. The last one is easier to understand and is included in the SDK.
You can also call setViewMatrix each FRAME in your manipulator.
Hope this can help
Monia
Hi mony84,
I thank your attention and available to try to help me. However, I still have many questions...
First: You used OSGVRPN in your code? If so, what link you used to donwload the library? What libraries or drivers I must use?
Second: Where I find the definition of the methods SbInit(), DispatchLoop()?
Third: In which part of your code you call your 3D application?
Fourth: I have tried to run the example, however, the compiler points out some errors in compiling...
1>c:\programas\microsoft platform sdk for windows server 2003 r2\include\atl\atlcom.h(3242) : error C2065: '_Module' : undeclared identifier
1>c:\programas\microsoft platform sdk for windows server 2003 r2\include\atl\atlcom.h(3242) : error C2228: left of '.Lock' must have class/struct/union
1> type is ''unknown-type''
1>c:\programas\microsoft platform sdk for windows server 2003 r2\include\atl\atlcom.h(3244) : error C2228: left of '.Unlock' must have class/struct/union
Do you have any idea?
I think perhaps it would be easier if I could see your code complete (main.cpp). I confess that things are still difficult for me
Is possible?
Thank you very much for your attention...
Is possible?
Hi mony84,
In my application, I connected the SpaceNavigator, but I don't understand the reason of instruction "if (g3DSensor)" of the method calc3DMovement ().
In my code, even if it does not happen any interaction with the device, the application enters this "if" and prints the values 0,0,0. I need to get the values of translation and rotation only when they actually occur.
I already have a main loop that controls the application. In this case, how I could use these methods in parallel without blocking the implementation of the application? How is your main loop??
Thanks.
Thanks.
