Can't adjust sensitivity in Fusion 360
tbaker2500
Post by tbaker2500 » Mon Oct 19, 2015 12:53 pm
Hi all you smart people!
Using the latest drivers, OS X Yosemite. SpaceNavigator. Latest Fusion 360.
I set the control panel app to All Programs, the adjust the sensitivity. No matter what I set it to, the sensitivity in Fusion does not change. I select Fusion 360 from the Program drop down dialog, again, the setting doesn't seem to make any difference at all. Any idea what I'm doing wrong?
Thanks!
Re: Can't adjust sensitivity in Fusion 360
Post by UtaSH » Tue Oct 20, 2015 5:35 am
Hello tbaker2500,
if you want to adapt the sensitivity for Fusion 360 you have to select "Fusion 360" from the drop down dialog.
It may be - for some strange reasons - that the com.3dconnexion.mappings.plist file is messed up.
So please try remove it (you may want to have it backed up before!) from ~/Library/Preferences/. (Please note: Before removal, close the System Preferences and thus the 3Dconnexion prefs.) If you now reopen the 3dconnexion prefs, a new/clean com.3dconnexion.mappings.plist is created. The mappings should work right away.
tbaker2500
Post by tbaker2500 » Wed Oct 21, 2015 11:14 am
Deleting the preferences worked!!
Many thanks.
