3ds Max viewport switching constantly
TD2000
Re: 3ds Max viewport switching constantly
Post by TD2000 »
Hi could anyone provide the v10.6.0 x64 for win10 driver for me again?. The link is expired.
Thank you.
TD2000
Post by TD2000 »
Hi can you post the driver again vor me please? The link is expired
luping
Post by luping »
TD2000 wrote: Thu Jan 14, 2021 4:30 am Hi can you post the driver again vor me please? The link is expired
v10.6.0 x64:
https://we.tl/t-zSzKGy758x
alexmarks3d
Post by alexmarks3d »
This is plaguing the latest driver again. Big regression for 3ds Max in latest driver
alexmarks3d
This post was created in 2014 and and this problem still persists. This is unbearable to work like this!!!! !@#&*Y^!@#&*^9874139087$@#)(*
mbonk
Post by mbonk »
n008 wrote: Tue Dec 22, 2020 9:12 pm Same issue here! Using latest driver: v10.7.0 on 3dsmax 2018.
In my case I noticed the camera switches to perspective but stays still with 3dsmax standard camera. On the other hand, if I use vray physical camera, or 3dsmax physical camera, the spacemouse driver rotates my cameras and leaves them rotated when I select any object on that viewport. It has become impossible to work with the new driver. The past drivers' issues were more manageable.
Does anyone have the v10.6.0 driver?? The link posted here is dead, It would be much appreciated!
Please send me a video and a screen shot of the '3Dconnexion Properties' 'Advanced Settings' both the 'Navigation Modes' and the 'Other Options' tabs (or tell me what they are).
Markus
thad
Post by thad »
Seriously, are you guys even trying to fix this?
mbonk
Post by mbonk »
alexmarks3d wrote: Tue Jan 19, 2021 11:21 pm This post was created in 2014 and and this problem still persists. This is unbearable to work like this!!!! !@#&*Y^!@#&*^9874139087$@#)(*
Not 2014
mbonk
Post by mbonk »
thad wrote: Wed Jan 20, 2021 3:28 pm Seriously, are you guys even trying to fix this?
Yes
The original poster joined in the Forum in 2014.
The post was created in 2019.
We're looking into this reports. Note that we can't reproduce the crashes or the instabilities.
We will appreciate if you can provide any details that can help us reproduce this issue. As mbonk requested, knowing what you driver settings are for 3ds Max (as found in the "Advanced Settings" panel of the 3Dconnexion Properties) may be important.
DinoNuggets
Post by DinoNuggets »
I just upgraded to the SpaceMouse Compact from the super oldschool SpaceExplorer when it stopped working.
I'm now getting the camera continuously jumping from the camera I have selected to perspective and back.
Can someone post the old download to the previous drivers again? The link died.
Thank you so much!!! ;P
need_old_drivers
Post by need_old_drivers »
Can someone post the drivers again that isn't a wetransfer link? Wetransfer expires after a few days. Maybe someone from 3dConnexion can post something permanent until there is a fix.
need_old_drivers wrote: Tue Feb 09, 2021 7:22 am Can someone post the drivers again that isn't a wetransfer link?
Our Technical Support team ought to be able to assist you. If you wish to contact them, the details are here.
luping
Post by luping »
need_old_drivers wrote: Tue Feb 09, 2021 7:22 am Can someone post the drivers again that isn't a wetransfer link? Wetransfer expires after a few days. Maybe someone from 3dConnexion can post something permanent until there is a fix.
v10.6.0 x64:
https://we.tl/t-Uu4p2XOCS5
Permanent link here, the download speed is not tested:
https://www.touslesdrivers.com/index.ph ... _langue=en
enzo_87
Post by enzo_87 »
Hi everyone,
same problem here on max 2021.
I tried the downgrade from 10.7.1 to the 10.6.0, but with those driver the mouse works fine in cinema 4d, but in my max don't even move around.
neither 10.6.3/4
10.6.9 moves around fine, but has the problem explained in this post.
all the setting for the mouse are the defautls one after the new install
