Maya 2020
omerkunul
Re: Maya 2020
Post by omerkunul »
Enough!!!
Still waiting now driver release.
Absolutely not working 2020 and 2020.1
:oops: :oops: :oops:
Janoshx
Re: Maya 2020
Post by Janoshx »
Driver 10.6.5 seems to be working perfectly with Maya 2020.1.
I haven't tried the 10.6.5 beta and wont if this keeps working.
Window 10 1903 (OS build 18362.720)
i9-7940x@3.1GHz / 64GB / Nvidia RTX Titan 24GB / Spacemouse Pro
omerkunul
Re: Maya 2020
Post by omerkunul »
hi thank you for quick reply.
but i keep getting errors.
beta driver install ss1
and old driver uninstall ss2
omerkunul
Re: Maya 2020
Post by omerkunul »
omerkunul wrote: Mon Apr 06, 2020 3:36 am hi thank you for quick reply.
Bit Rage
Re: Maya 2020
Post by Bit Rage »
I have a 3D Space Explorer i just got in brand new condition and i cannot open any Maya 2020.1 model without most of the geometry missing, it shows in the outliner but not there, inly like a peice of the model geometry shows.... Its working fine in Inventor and 3D Studio MAX, Mudbox, Blender, ect.
Whats the issue!?
omerkunul
Re: Maya 2020
Post by omerkunul »
error buggy - error - bug , fail, error, maya, 3dxware v.?!
please watch the screen recording..
https://youtu.be/VnM_SmeAY4w
Bit Rage
Re: Maya 2020
Post by Bit Rage »
If any1 having the issue of geometry disappearing after reloading a scene i have figured out thar if you select all geometry in the outliner and then freeze transformations the geometry will reappear, But then when saved ans reloaded again you have to select all geometry. tranform (move) it all at once in any direction and THEN again freeze transformations again and it reappears. This is NOT a fix just a temporary workaround.
Re: Maya 2020
Bit Rage wrote: Fri Apr 10, 2020 10:49 am I have a 3D Space Explorer i just got in brand new condition and i cannot open any Maya 2020.1 model without most of the geometry missing, it shows in the outliner but not there, inly like a peice of the model geometry shows.... Its working fine in Inventor and 3D Studio MAX, Mudbox, Blender, ect.
Whats the issue!?
Hi Bit Rage,
the SpaceExplorer is a legacy device and our latest driver - 3DxWare 10.6.5 - doesn't recognize it. But as far as I know you need this driver version for Maya 2020. I recommend to get a more recent product.
Re: Maya 2020
omerkunul wrote: Sat Apr 11, 2020 6:30 am error buggy - error - bug , fail, error, maya, 3dxware v.?!
Hi omerkunul,
from the About window in your video there seem to be something messed up with the installation. It says you have 3DxWare 10.5.15 installed, but you have 3DxWinCore 17.6.5. These two versions do not belong to each other. I recommend to uninstall all 3Dconnexion driver software and re-install the latest driver. Then reboot and see if the situation changed.
tmcthree
Re: Maya 2020
Post by tmcthree »
10.6.5 still destroying geometry for me.
Now it also completely crashes Maya when navigating in a vray IPR window.
Completely unusable with Maya now.
Windows 10
3770k
Quadro m4000 x2
Maya 2020.2
Quadro driver 442.74
Bit Rage
Re: Maya 2020
Post by Bit Rage »
UtaSH wrote: Fri Apr 17, 2020 2:24 am
Whats the issue!?
Hi Bit Rage,
i mostly only use the navigation knob, which supposedly hasn't changed at all to the new models, i got a brand new one for 80 bucks, i dont want to get just the knob due to it moving around on the desk, and others are 200+... i dont understand how an updated driver cant be made to work when the model benith the enterprise is ALMOST IDENTICAL to the explorer.
Re: Maya 2020
Hi all,
we released a new driver version yesterday - 3DxWare 10.6.6. have you already tried this one? Do you see an improvement?
TomKoe
Re: Maya 2020
Post by TomKoe »
UtaSH wrote: Tue Apr 21, 2020 2:23 am Hi all,
Now, the Buttons of the SpaceMouse Pro are not working (nor in Maya or Windows or whereever). Yes, i tried to not just update - i also reinstalled.
Guys, pleeeeeeeaaaase! Do you test your versions before rolling them out?
TomKoe
Re: Maya 2020
Post by TomKoe »
to be precise: The Buttons on the left side: "esc", "Shift", "ctrl" and "alt" are even not working in Windows, and the ones on the top: "1", "2", "3" and "4" are not working in Maya anymore. All the other Keys are fine (it seems for now).
TomKoe
Re: Maya 2020
Post by TomKoe »
TomKoe wrote: Tue Apr 21, 2020 4:54 am to be precise: The Buttons on the left side: "esc", "Shift", "ctrl" and "alt" are even not working in Windows, and the ones on the top: "1", "2", "3" and "4" are not working in Maya anymore. All the other Keys are fine (it seems for now).
to be even more precise: it seems that all "keyboard shortcuts" are not working. I have set my keys to 1-move 2-rotate 3-scale 4-maya hotbox. When i choose "maya move tool" instead of the shortcut "W", it works. But i see no workaround for the four left buttons.
Anmerkung 2020-04-21 142039.jpg (60.63 KiB) Viewed 10932 times
