Latest drivers for Space Pilot on Win10
philnolan3d
Post by philnolan3d » Mon May 20, 2019 7:52 pm
I've been noticing that my Space Pilot (not Pro) starting acting funny in 3D-Coat recently, the navigation is extremely sensitive in the panning, I've turned the 3 sliders all the way down and it still moves very fast with the slightest touch. If I turn the main speed down the rotation slows down but the pan is still super sensitive. So I thought I'd update my driver. It seems I'm still on 10.2.9 that I downloaded in 2015. But now it looks like the Space Pilot is no longer supported. That being very disappointing, I wonder if anyone can tell me the latest 3DxWare that supports it and where I might be able to download that? Thanks.
Phil Nolan
3D Generalist
http://www.philnolan3d.com
Win 10 Home x64, Core i7 3.4 GHz, GeForce GT 640, 16GB RAM
aalsalihi
Re: Latest drivers for Space Pilot on Win10
Post by aalsalihi » Wed May 22, 2019 7:00 am
Hi Philnolan3d,
SpacePilot is not supported device which is correct. Regarding the driver, it looks like 3.16.3 is the driver version supported for the SpacePilot device.
You could download the driver by:
- visiting this link to download drivers: https://www.3dconnexion.com/service/drivers.html
- Click on Archived under Additional Software and Drivers
- For the Product Select SpacePilot from the list
- Then hit search
- Pick the operating system you have, then download the driver and proceed
Abdul. A
philnolan3d
Post by philnolan3d » Thu May 23, 2019 1:56 am
Thanks. Unfortunately entering Windows 10 doesn't work, but I found that by pick Win 8.
Phil Nolan
3D Generalist
philnolan3d
Post by philnolan3d » Thu May 23, 2019 2:01 am
Actually 3.16.3 can't be right, the one I'm using is newer, 10.2.9
Phil Nolan
3D Generalist
Post by jwick » Thu May 23, 2019 2:10 am
Hi Phil,
That web site doesn't seem right. I assume you got a released driver after the beta testing was done.
In any case, you probably don't need a new driver. And you can't use the latest few versions because the SP isn't supported.
Is there something wrong with your hardware? Broken spring, bad LED? Do our demos show the same super sensitive behavior?
Jim
SpaceName
Post by SpaceName » Fri Jun 07, 2019 12:22 pm
@PhilNolan3d
I think I am experiencing a similar issue but the fact that they reuse model names through generaitons of the model line is stirring fierce confusion and frustration without any form or method to clarify the issue to a resolve besides my installing 6-8 packages until I find the right one.
I am not sure what is happening at 3dConnexion .. but they're being rather sloppy with their support section leaving people to dig into nonsensical re-used terms on multiple products without differentiation of any form.
