SpacePilot confusion
Hello - I'm having trouble with my SpaceMouse Pro getting confused as to what application I'm running. I primarily use Fusion 360, but I also have Inventor installed. While using Fusion, the SpaceMouse will often stop responding. If I hit the Menu button, I see that the SpaceMouse thinks I'm running Inventor (which is not running).
Re: SpacePilot confusion
Hello meobeou,
see if removing the existing settings solves the issue.
If not I suggest you create a log file of the driver and contact our Technical Support Team.
