3DConnexion Drivers for Mac OS Mojave
Re: 3DConnexion Drivers for Mac OS Mojave
No more news from 3Dconnexion ...
For me it is not 100% useless.
3D nubby works, everything else works too for me,
it is just to risky to use as I can't see my functions assigned,
as the Screen stays dark on my Enterprise.
Of course I can't edit my settings in driver panel too.
Not happy with macOS driver release cycles either.
(I was already clear that the driver doesn't work that way with new kext and
privilege policy in High Sierra)
But I hope if there are larger works on the driver, that we Mac Users will finally
get feature parity with Windows Users - Display Icons.
This is causing a lot of problems for a lot of people. Do you have an ETA on the new driver?
Looks like Enterprise's Display works again after macOS 10.14.1 Update.
I see my usual Button Texts.
Driver Panel reacts but does still not show any devices - but brings a 32 bit Warning
for the Check Update.
Come on, guys! It's now over a month since the release of macOS Mojave (not to mention months of public beta before that). They just released the first update to Mojave. You are pretty much creating a self-destroying attitude that will ensure you never have growth in you Mac customer base.
I was very happy to see that there is finally an updated driver for Mac OS available. But I installed it, and it does not work. In System Preferences: 3Dconnexion there is still "No Device Found". And in Sketchup, when activating the 3DxSketchUp Extension, the application starts eating memory, and my Space Navigator does not work.
3DxWare 10 for macOS macOS 10.6.0 31.10.2018
NOT WORKING!
NOT WORKING!
I try to install a new drivers for macOS: 10.6.0 released on 31.10.2018 but not Working with Mojave.
my configuration:
macOS Mojave 10.14
Nome processore: Intel Core i7
Velocità processore: 4 GHz
Numero di processori: 1
Numero totale di Core: 4
Cache L2 (per Core): 256 KB
Cache L3: 8 MB
Memoria: 24 GB
my configuration:
macOS Mojave 10.14
Cache L3: 8 MB
Memoria: 24 GB
Now we have the new driver but the radial menu of the CAD mouse looks wrong.
Driver 10.6.0 (released on 31/10/2018)
https://www.3dconnexion.eu/service/drivers.html
Didn't change a thing for me. Still running into the same issues others are encountering.
- Device can not be found
- No functionality, except for basic cursor movement within Sketchup, 3D connexion viewer/trainer and other programs I use with this product.
Removed driver, reinstall driver, restart+command R and terminal and all that.
As a designer and engineer I'm dependent on the tools I use for work efficiency. Right now im dead in the water with this product and have to work slower with just a normal mouse.
I've read all the posts and information I can find online regarding 3DConnexion and Mojave and I can't seem to find anything that works up until this point.
I'm sure your team is on top of the situation, but you guys are way behind other companies that had to resolve issues regarding Mojave.
FRUSTRATING!
FRUSTRATING!
OK, I discovered a Mojave update,14.1, so I installed that.
Then I reinstalled 3DC drivers again, and restarted for that.
No change.
So I can't think of anything else to try. It doesn't even work in Viewer.
No change.
Hi all,
I apologize for not posting earlier here. As you already noticed we have released the new driver for macOS which is ready for macOS 10.14. This is 3DxWareMac 10.6.0 and can be downloaded here.
Important: Please review as well our FAQ #1141. You will find important installation notes there. In case you still have problems after following the steps from FAQ #1141 please contact our Technical Support Team for further troubleshooting.
Hello RicoHo,
sorry for the problems. We assume that this is related to the resolution that you have. Does your mac have a retina display?
We are tracking this issue with our internal bug tracking number #MAC-72.
Für mich funktioniert der neue Treiber.
Geräteauswahl ist wieder erreichbar,
bisher keine 32 bit Warnungen mehr,
Display zeigt auch wieder (zuverlässig) an.
Ich drücke die Daumen dass es so bleibt.
Vielen Dank an 3DConnexion !
I do have a retina display. On a iMac (Retina 5K, 27-inch, Late 2014, 4 GHz Intel Core i7, AMD Radeon R9 M290X 2048 MB). You have tested the new driver, but not on one with a retina display? Seriously?
