space mouse manual sensitivity control with the two buttons
Re: space mouse manual sensitivity control with the two butt
Of course. You have to provide the correct ExecutableName for the driver to match the cfg file with the C4D executable.
cesern
Post by cesern »
Hi, I was wondering if you could take a look at a capture desktop video of me trying to follow the instructions and see what I'm doing wrong.
Thanks for all you help. https://www.dropbox.com/s/43nmpig9trwjp ... t.avi?dl=0
You are close. I suspect the executable names are wrong. Hover the 2d mouse over the 3Dx systray icon when C4D is running. It should show the executable name of the specific version of C4D that you are running.
The file I included below has <ExecutableName>Cinema 4D 64Bit.exe</ExecutableName>.
I suspect this is not your C4D exe name.
Change that line to whatever the exe name is that is reported on the systray icon.
You may also want to save the xml file under that name. You put the Cinema 4D 64Bit.xml contents into Cinema 4D.xml.
If you rename the file, then you have to change the filename in the xml file:
      <Arg>.\ChangeSettingsTScale.ps1 &apos;Cinema 4D 64Bit.xml&apos; 2</Arg>
cesern
Post by cesern »
Hi, The version shown on the 3Dx tray is "CINEMA 4D R17.001 ST..."the only other clue I get on what version is by looking at the Cinema root exe file which is just CINEMA 4D. I've tried taking out the excess "64Bit" part from the code to match, but still no new items.
I appreciate all the help this last couple of weeks.
do you think there's any hope on an update in the future?
You just have to get the exename right and it will work. C4D does have a tradition of untraditional exe names.
You can also look in the Task Manager to see what the exe name is.
The 3DxService.log file will also show the exename. You can PM that file to me. (Turn on logging in the 3Dx systray icon. Switch to C4D. PM me %localappdata%\3Dconnexion\3DxWare\3DxService.log.)
cesern
Post by cesern »
00000001 10:26:28.551: CtlRes: UdCtlInitRes: Defaulting to en-US resource: The specified module could not be found.
ffffffff 10:26:28.552: ChangeRunningGUIState: Flags.productID = , lParam = 0x0
cesern
Post by cesern »
the items have finally showed up (halve trans scale and double trans scale). I have assign them to the buttons, but it doesn't work. Everytime I press the buttons A dark blue screen shows up with some red text. The 3dx tray detects this window as "window powershell"
PM sent
cesern
Post by cesern »
PM sent from cesern
cesern
Post by cesern »
PM sent
cesern
Post by cesern »
Hey just wondering if you got my last PM about my files.
Oh, sorry. I was waiting for the files.
I've responded to your email address.
We can take this off-forum now.
surya
Post by surya »
Hello team,
I'm facing issue with 3dmouse rotation while using 3dexperience delmia. 3dmouse settings not taking into 3dexperience user settings. let me know if any possible way to sort out this issue. quick response would be appreciated.
Hello surya,
what kind of problems do you encounter? Is rotation available? Can you navigate with the 3D mouse in 3DEXPERIENCE?
What kind of settings are not accepted? Please explain more in detail. Thanks.
Moved topics about Cinema 4D to the Windows Discussion forum.
