it a choice i ve made , because , if u move SpaceNav while ur in Edit screen to see value of axis (ie for Min/Max/Deadzone ) , it should be difficult if u have some "Alt-Tab" Bind or other key bind running ...systemsuperuser wrote:Hi
@RBC9:- When u are in the Edit Layout screen , the driver stop sending to Joystick Mouse and Keyboard. The driver restart when u leave this screen.
Why does the driver stop when you're on the edit screen? For me, using the device sometime as a mouse replacement it would be very convinient to use it also on the edit screen.
systemsuperuser wrote: And, using it as a mouse: May it be possible to add a control to the GUI allowing to set the mouse speed? (Windows has one global mouse speed setting - this one affects all connected mouses. It's not possible to adust the mouse speed of different mouses individually.) As I use the SpaceNavigator sometimes as mouse replacement this would be a nice feature.
there is a "Sensitivity" value for each Mouse Move bind.
i ve create a "Dummy Layout" , and i use Autoswith for all the app i want to turn off my driver.systemsuperuser wrote: Is there a way to stop the driver other than by opening the Edit Layout screen? During let's say Google Earth exploration you might want to have this driver stopped. Creating an Google Earth layout without any binding should do this, I guess.
But it sould be add as a feature , a On/Off option in Systry menu.
Happy to help u. May be i ll have time in futur to come back to this driver dev .... but not for the moment.systemsuperuser wrote: If you ever might consider to add more features to the driver, maybe you could consider my input. The driver works very well, and I'm very satisfied with it. Thanks!
