Is there any binary protocol documentation?
travisfw
Post by travisfw »
I would like to parse the bytes coming over the the wire from my USB SpaceNavigator. For example, when I press the left button, I clearly see this pattern of bytes each time: 0x03, 0x01, 0x00, 0x03, 0x00, 0x00. The data from 3D translation and rotation have, so far, confounded me. Here is an example of tapping the top of the SpaceNavigator once:
01 f8  ff 14  00 55  00 02  00 00  15 00  00 00  01 00
00 b0  ff 04  00 02  a5 ff  00 00  00 00  01 00  00 00
00 4b  00 02  65 00  fe ff  00 00  01 00  00 bd  ff 00
00 02  d7 ff  08 00  00 00  01 00  00 1e  00 cd  ff 02
37 00  00 00  00 00  01 00  00 f1  ff 00  00 02  b8 ff
00 00  00 00  01 00  00 2b  00 14  00 02  26 00  00 00
00 00  01 00  00 f5  ff 00  00 02  d1 ff  00 00  00 00
01 00  00 19  00 f5  ff 02  2b 00  00 00  00 00  01 00
00 eb  ff 00  00 02  d9 ff  00 00  00 00  01 00  00 04
00 00  00 02  23 00  00 00  00 00  01 00  00 fe  ff 00
00 02  f3 ff  00 00  00 00  01 00  00 00  00 00  00 02
09 00  00 00  00 00  01 00  00 00  00 00  00 02  ef ff
00 00  00 00  01 00  00 03  00 00  00 02  08 00  00 00
00 00  01 00  00 00  00 00  00 02  f5 ff  00 00  00 00
01 00  00 00  00 00  00 02  07 00  00 00  00 00  01 00
00 00  00 00  00 02  f7 ff  00 00  00 00  01 00  00 00
00 00  00 02  07 00  00 00  00 00  01 00  00 00  00 00
00 02  f8 ff  00 00  00 00  01 00  00 00  00 00  00 02
05 00  00 00  00 00  01 00  00 00  00 00  00 02  fc ff
00 00  00 00  01 00  00 00  00 00  00 02  00 00  00 00
00 00  01 00  00 00  00 00  00 02  00 00  00 00  00 00
01 00  00 00  00 00  00 02  00 00  00 00  00 00  01 00
00 00  00 00  00 02  00 00  00 00  00 00  01 00  00 00
00 00  00 02  00 00  00 00  00 00  01 00  00 00  00 00
If anyone can help me see how to build 3D transform matrices out of this data stream, or otherwise help me see how to parse each of the six degrees of freedom, that would be much appreciated. Ideally there's official documentation somewhere (I'm not feeling lucky).
Backstory: I'm playing around with JavaFX 3D, and I want to make use of this SpaceNavigator that has been gathering dust for a year or so. I'm on Fedora 24. I've tried every Java library I can, and they all fail, and none seem to have legible source code (that I have stumbled across) that parses the binary protocol. Most recently I have attempted to read the C (++?) code in svn://svn.code.sf.net/p/spacenav/code but have not found this to be enlightening, perhaps because I'm not proficient with C. I'm avoiding JNI in my own solution because headaches. I can simply pipe /dev/hidraw2 into my JVM and read it with an InputStream, and that's good enough for this hobby-level project. Who knows; the project could evolve eventually, but I'm not getting ahead of myself.
steve s
Re: Is there any binary protocol documentation?
Post by steve s »
I had a similar question last week, but was able to make progress (at least for my two devices: SpacePilot & SpaceNavigator, which appear to behave the same way).
I'm using HID interface on Windows to gather data (as others have suggested on this forum); looks as if you're getting a similar stream of data. Like you I'm ultimately in Java.
Here's what I'm doing; you may need to tweak a few things on Linux, but maybe not:
Group the data stream into 7-byte packets. The zeroeth byte of each seven-byte packet will be either a 1 (translations), a 2 (rotations), or a 3 (button events).
Each 1 packet (the translations) will be followed by a 2 packet (rotations); but the 3 packets (button clicks) stand alone, and I'm not going to address those button packets...each device has more or less buttons.
Once you've seen a 1 packet followed by a 2 packet, that means there's an additional 12 bytes. If we number those bytes 1, 2, 1, 2..., you can use the code below to combine them into signed shorts, yielding 6 signed short values: three for translation, and three for rotation.
Here's my Java code:
	private short combine(byte b1, byte b2)
		ByteBuffer bb = ByteBuffer.allocate(2);
		bb.order(ByteOrder.BIG_ENDIAN);
		bb.put(b2);
		bb.put(b1);
		return bb.getShort(0);
Others on this forum have noted that the inputs are in the range +/- 512, and I've found that to be true (actually I've never seen a value beyond +/- 400 for either of my devices, but they both definitely balance on a zero-valued short, which is the important part).
If we number those shorts 0 through 5, here's the interpretation (positive direction first, then negative values):
Three Translations:
  • 0: right / left
    1: pull toward user / push away
    2: push down / pull up
Three Rotations:
  • 3: twist toward user / twist away
    4: twist left / twist right
    5: twist CW / CCW
suspect your mileage will vary if user reconfigures the device, but I'm pretty sure this is the out of the box behavior.
Hope this helps.
Steve
