google earth and space navigator PE freeze the system
- Contact:
I've got the space navigator and google earth. All versions and drivers are uptodate, so I'm a little bit disappointment, that my system will stop when I'm using google earth by flying with the Space navigator.
The full system freeze while I'm navigating. Not only Google earth it is really the full Mac os 10.4.10 whith all processes which stopped.
Did anyone have the same problem?
Marek
Marek
I've been trying to install spacenavigator pe on a new macbook pro. I have OSX 10.4.9, the MBP has 2 GB of sdram and the 2.2 Ghz processor. I've tried to install at least 4 times and at the end of the process, when the installer offers to show me how to use the device--the computer freezes with a cryptic message that I need to restart. I have to hold down the power key to shut down the computer because it doesn't repond to keystrokes of mouse moves.
I just migrated to the Mac after years on PCs and this makes me feel all nostalgic, although it only dims the screen--doesn't go all blue.
What's the story?
What's the story?
DB in Brooklyn
Usually when a crash like that happens, a crash report log is generated and the next time you restart, the OS will ask you to send it to Apple. If you see this, do a view report and send us the data.
You can also grab all of the crash logs in your ~/Library/Logs/CrashReporter folder
I'll send you a note with my email
Sorry, just found the log. It wasn't where you sent me. Here it is.
Mac OS X Version 10.4.9 (Build 8Q1058)
2007-06-29 11:38:20 -0400
Jun 29 11:38:24 andrew-morris-computer ntpd[162]: bind() fd 12, family 30, port 123, addr fe80:8::201:23ff:fe45:6789, in6_is_addr_multicast=0 flags=0 fails: Can't assign requested address
2007-06-29 11:38:24.728 SystemUIServer[80] lang is:en
2007-06-29 11:51:39.983 DashboardClient[222] com.kamalaboulhosn.radarinmotion2: illegal type passed to setPreferenceForKey: <WebUndefined>
Jun 29 13:20:04 andrew-morris-computer configd[33]: Error: Failed to join most recent network "dbnetwork", err=88001006 (will search for any others)
Ignoring Quickdraw drawing between QDBeginCGContext and QDEndCGContext
Jun 29 14:03:09 andrew-morris-computer ntpd[162]: sendto(17.254.0.27): Can't assign requested address
Jun 29 14:39:56 andrew-morris-computer configd[33]: Error: Failed to join most recent network "dbnetwork", err=88001006 (will search for any others)
Jun 29 15:11:24 andrew-morris-computer ntpd[162]: sendto(17.254.0.27): Can't assign requested address
Jun 29 16:19:42 andrew-morris-computer ntpd[162]: sendto(17.254.0.27): Can't assign requested address
Jun 29 16:37:54 andrew-morris-computer crashdump[355]: Finder crashed
Jun 29 16:37:54 andrew-morris-computer crashdump[355]: crash report written to: /Users/andrewmorris/Library/Logs/CrashReporter/Finder.crash.log
/Users/build_guy/Development/SketchUp/Source/MacApp/../BaseApp/../Model/../Utils/../MacWin/CString.h:372: failed assertion `nIndex <m_pData>nDataLength'
3DxSketchup Plug-in: [83] Initializing...
3DxSketchup Plug-in: [115] 3Dconnexion device initialized. Client ID: 8197
3DxSketchup Plug-in: [126] Initialization complete.
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
free_Command
DB in Brooklyn
Hi!
I can inform you that I've also got similar problems, and I'm running Vista on my computer. My problem is that Google Earth hangs after a few minutes of use, every single time, and it's getting really anoying!
I have saved a dump and can send it to you if you provide an email adress...
Regards
/PeterH
Regards
/PeterH
I finally today got the spacenavigator installed on my Macbook Pro. The one step that screwed up the installation was to agree to learn about configuration before finalizing the install. I don't remember the exact side trip, but instead of finalizing I clicked the other alternative.
Since restarting the MBP, I had one freeze with Google Earth, but was able to close the program after unplugging the SN.
Hope this is helpful.
DB in Brooklyn
I've got the exact same problem as mnierychlo pointed out in his post:
MacBook Pro with 2,16 GHz, 2gig ram. Mac OS X 10.4.10 all up to date. The 3DConnextion "Driver" is the latest available on the home page (1.3.0).
It doesn't seem to generate a crash report in the location you pointed flomotan to, there's no such log for today. And it hung twice today....
Any suggestions?
Thanx, SkyGTQ
This is getting pretty annoying, since there's no way to just shut down Google Earth. The whole system is not responding, mouse is frozen. Sometimes it just reboots after 20 seconds being frozen.Hello,
Marek
Any suggestions?
Thanx, SkyGTQ
Which version of Google Earth are you running? The latest version today is 4.2.0198.2451. Please try that version if you're not already running it.
Getting a crash log or some reproducible steps would really be helpful. Any details that can help us duplicate the issue is also welcome. Some things to pay attention to when the crash occurs...
- Was there a specific action you did (eg load a kml, navigate to the south pole)
- It's crashing after a certain number of minutes or hours of continuous navigation
- What other applications/processes are running
- Any kind of pattern of use that leads to a crash
- Contact:
I'm using the newest version of google earth and mac os x and space navigator. I've got the freezes with 10.4.9 and with google earth 4.1.x.
I don't do anything special. Just navigate through the world or using the new flight modus.
It not depends on time. Sometimes it freeze after 2 min and then again after just 1. Sometimes I can do what I want.
No other apps running while it's freeze. I can restart my iMac and the problem accurs after some minuntes.
marek
marek
- Contact:
Flomotan-
yes, the freezes are still there with updated GE and updated Max OS X. But I can't give you any important informations, because the freezes occured in different situations.
I'll hope that leopard will be out in a few days, so I'll try it with a clean install. Not only for google earth, but I got two oddities more.
Marek
Marek
