Cadmouse: Middle mouse button double-click issue
RANS0M
Post by RANS0M »
Hi guys,
The Cadmouse is great but I have an issue:
I click and hold to the middle mouse button to pan in AutoCAD. However sometimes AutoCAD will 'zoom extents' instead of panning. Zoom extents should only happen if I double click the middle mouse button, not click and hold.
The issue doesn't occur all the time, but every now and again. When it is happening, it will occur around 1 in 10 times I pan. Does anyone have similar issues or ideas on how I could perhaps fix it? I feel like perhaps dust got inside and is affecting the button motion. But opening up the mouse to try and clean it is beyond my capabilities.
Cheers,
Pete
Re: Cadmouse: Middle mouse button double-click issue
Hi Pete,
you might be right with your guess that the issue is related to the device itself. I suggest you contact our First Level Support Team and they will do some troubleshooting with you and if necessary start the RMA process to get a replacement to you.
RANS0M
Post by RANS0M »
Thanks for the reply UtaSH, I'll follow your suggestion.
archinaut
Post by archinaut »
I've been experiencing a similar issue with my Cadmouse's left button: a single click enters a double click.
This only started happening about six months ago first occasionally and now constantly.
Has anyone reported/experienced a similar issue?
Hello archinaut,
please contact our Technical Support Team. They will do the necessary troubleshooting with you and if this doesn't help they will start the replacement process.
