Spacemouse Pro - Here we go again.....
My Spacemouse Pro is almost useless within Solidworks and have therefor been laying in desk drawer. In hope to get it to work better, I updated from V10-1-4_r1818 to 3DxWare64_v10-2-8_r2007 today, in some last hope to get it more precis when manipulating within Solidworks. As it is now, It works PERFECT in the included trainer, but not as near as well in Solidworks.. I WANT THAT CONTROL IN SOLIDWORKS as well.... but NO...
The upgrade seemed to work well but after that I got an error about some 3Dxserver that couldn't start. I ignore it and for the first time it seemed to work fine with Solidworks... For 30 min... Then it stopped working. It did not work with Chrome either. The trainer worked well though. Uninstalled 3Dware, restarted the computer and then installed it again. But now i got some error 1714 (See attached pic) telling me that some old Solidwork files were locked... Deleted all folders and files that i could find, tried again, but same problem occurred every time. Started to delete the 3dconnexion keys in the register, but the keys were locked and could not be deleted
What to do?????
z
What to do?????
z
- 3DWare problems.png (3.93 KiB) Viewed 12899 times
Re: Spacemouse Pro - Here we go again.....
More error pictures....
- 3DWare problem3.png (15.2 KiB) Viewed 12896 times
- 3DWare problem2.png (5.96 KiB) Viewed 12896 times
The error messages is:
Problem signature:
Problem Event Name: BEX
Application Name: 3DxNLServer.exe
Application Version: 1.0.15212.11646
Application Timestamp: 55bb81d6
Fault Module Name: 3DxNLServer.exe
Fault Module Version: 1.0.15212.11646
Fault Module Timestamp: 55bb81d6
Exception Offset: 0009cf47
Exception Code: c0000417
Exception Data: 00000000
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1053
Additional Information 1: f703
Additional Information 2: f703893ab1453b28b41a14de3a5a1fd2
Additional Information 3: ddec
Additional Information 4: ddec8134fa583572a5aa2e0312ce9341
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Problem signature:
Locale ID: 1053
I dried to install the old version but without any success. Same errors
New Error:
- 3DWare problem4.png (5.97 KiB) Viewed 12896 times
NOW IM GETTING UPSET..... I cant longer open my Solidworks...
Getting this message.
- 3DWare problem5.png (5.47 KiB) Viewed 12895 times
Uninstalled the crap, But it destroyed something within Solidworks...
It won't start anymore...
- 3DWare problem6.png (69.62 KiB) Viewed 12895 times
No, i'm not running out of disk space
A system restore solved the Solidworks problem... But still, the 3Dware does not installs properly
But still, I can't uninstall the 3Dxware. Getting this error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: set4C0D.tmp
Application Version: 9.1.0.429
Application Timestamp: 3fb01c5d
Fault Module Name: set4C0D.tmp
Fault Module Version: 9.1.0.429
Fault Module Timestamp: 3fb01c5d
Exception Code: c0000005
Exception Offset: 0000814b
Locale ID: 1053
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Problem signature:
Locale ID: 1053
- 3DWare problem7.png (14.13 KiB) Viewed 12891 times
downloaded IObit Uninstaller 5 and that program uninstalled the 3Dxware.
But how do i get around the locked "2005-2016 Solidworks" files??
How could this 3DxWare mess up my computer so badly. Have spent 9-10 hours to clean all up, but still can't install neither the new or old 3DxWare.
What is it, and how to get rid of the blocking features? Solidworks seemed to work well with the new 3DxWare, at least for half an hour.
Opening a few other program (programs that were earlier configured to worked with the Spacemouse pro) results in Spamsemouse error, see below. It seams that 3DxWare has left some register keys/files/other, things that I now have to be clean up manually.
Please let med know where to look and what to change/delete
- 3DWare problem8.png (20.79 KiB) Viewed 12827 times
Are there no support folks here on this forum?
