3dconnexion for Sketchup 2013 does not work !!
madeharo
Post by madeharo »
The current driver 3.16.3 for sketchup 2013 does not work. (In windows 7 - 64)
I read that all users of the new version of Sketchup same thing happen to them.
We are expecting a new revision of the driver or any urgent patch to solve the problem.
Thank you.
Fred
Re: 3dconnexion for Sketchup 2013 does not work !!
Post by Fred »
You will have to wait for the programmers to create a new addin for Sketchup 2013.
They have made too many changes and our current addin will not work.
madeharo
Post by madeharo »
Ok... Thank you.
Jerryki
Post by Jerryki »
This is a killer for me in adopting Sketchup 2013.
How soon will the new driver be available?
Bryan
Post by Bryan »
Dear Jerryki,
You may reference this post:
SketchUp 2013 Plug-In
Sincerely,
Bryan
madeharo
Post by madeharo »
Solved !!!! ... In version 3.17.3.
Thank you.
Traupmann
Post by Traupmann »
Sketch Up 2013 is not working for me. Sketch Up 8 worked great. I have the correct driver 3.17.3, but "nothing is SOLVED" here.
Does someone know the magic dance or the correct throwing of the chicken bones?
Hello Traupmann,
please try a clean uninstallation and re-installation as described here. Let me know if this helps.
Rickymon
Post by Rickymon »
wil try that, is not working for me
Hopefully maker 2013 does not replace Google sketchup....
How do u like sketchup 2013?
mclaser
Post by mclaser »
I have SP (non Pro, I guess), Win7-64, Sketchup 2014. The 3d software loaded fine and the demos all work great. Nothing happens in SU. I've double checked that the the Sketchup pluggin is checked. Does this configuration not work together? Based on this thread it looks like SU 2013 did work with this combination. Is that my only option (besides buy more hardware)?
Thanks.
Fred
Post by Fred »
mclaser check your Forum message box.
HPPAVILIONG7
Post by HPPAVILIONG7 »
Fred wrote:mclaser check your Forum message box.
Hey Fred I have a SpacePilot and im useing Skp2014 is there a file or driver that makes it work because I cant get i to work....
Fred
Post by Fred »
We would like to clarify that SpacePilot was discontinued in March 2010 and software support was maintained for three years. This means we continued to test the product with all new drivers until March 31st 2013.
After this date, we did not take any steps to stop SpacePilot working, but it is not tested with newer drivers. This means we do not list these drivers when you search for SpacePilot on the driver download page. However, if you download our latest driver (3DxWare 10.1.0 or 3DxSoftware 3.18.0) by searching for another product (I suggest SpaceMouse Pro or SpacePilot Pro), there is a chance it will work fine with your SpacePilot and <new application name>. Please be aware that because SpacePilot is not tested with this driver we will not be able to offer further technical support (but we hope that is not necessary).
