control panel recommendation
I have to check and uncheck options in the advanced settings control panel tab a lot for things such as drive/walk through movement simulations. Something that would help me a lot is if future builds of the panel included a “check all” and “uncheck all” button. Just a thought.
Thank you very much for the suggestion. It was something considered in the past -- as we plan for future updates, it's something we will look at.
On the Application Configuration, you can reverse all by selecting reverse all axes. If all are checked or unchecked, this will accomplish what you are describing. It just reverses whatever your selection is.
Ziva Nissan
3Dconnexion, Inc.
Ziva Nissan
3Dconnexion, Inc.
Well I'm basically freezing movement so that I can slide down a sidewalk or street without tilting, raising or dropping the camera. When I do that the only thing I keep active is spin and zoom. The check/uncheck button would just let me do that faster when I’m doing this if front of clients. I’m not sure that reversing will help that but I’ll play with that as a solution to some other ideas.
