Android support
robert_ugo
Android support
Post by robert_ugo »
Is there any sollution to plug 3dconnexion to android or iOS tablet? Im working on remote controler for robot and it would be nice to use it in my project.
On android im thinking about build custom kelner with build-in drivers and then in some way comunicate with driver from aplication.
Its good way or there is other (better) solution?
Re: Android support
Our devices are standard HID USB devices. You can read directly from them in the latest version of Android.
I don't know much about iOS.
robert_ugo
Re: Android support
Thanks for answer! Its easier than i thought.
But there is any API how can i talk with 3dconnexion via USB?
Re: Android support
You need to use the Usb* classes.
Here is some code I cut out of a demo we created.
It reads the data but doesn't do anything more than log it.
Expect to find some cut and paste errors in here. If you are an Android developer, it should get you started.
As I recall, this code originated in a USBTest example.
    private UsbManager mManager;
    private UsbDevice mDevice;
    private UsbDeviceConnection mDeviceConnection;
    private UsbInterface mInterface;
    private UsbEndpoint mEndpointIn;
    private PendingIntent mPermissionIntent;
    private static final String ACTION_USB_PERMISSION =
    	    "com.android.example.USB_PERMISSION";
    private final WaiterThread mWaiterThread = new WaiterThread();
    public long[] t = new long[3];
	public long[] r = new long[3];
    @Override
	public void onCreate(Bundle savedInstanceState) {
		super.onCreate(savedInstanceState);
		setContentView(R.layout.main);
        mManager = (UsbManager)getSystemService(Context.USB_SERVICE);
        mPermissionIntent = PendingIntent.getBroadcast(this, 0, new Intent(ACTION_USB_PERMISSION), 0);
        // listen for new devices
        IntentFilter filter = new IntentFilter();
        filter.addAction(UsbManager.ACTION_USB_DEVICE_ATTACHED);
        filter.addAction(UsbManager.ACTION_USB_DEVICE_DETACHED);
        filter.addAction(ACTION_USB_PERMISSION);
        registerReceiver(mUsbReceiver, filter);
        // check for existing devices
        for (UsbDevice device :  mManager.getDeviceList().values()) {
            mInterface = findInterface(device);
            if (findEndPoints(mInterface)) {
            	setUsbInterface(device, mInterface);
                break;
    private UsbInterface findInterface(UsbDevice device) {
        int count = device.getInterfaceCount();
        for (int i = 0; i < count; i++) {
            UsbInterface intf = device.getInterface(i);
            if (device.getVendorId() == 1133) // 3Dx devices
                return intf;
        return null;
	protected boolean findEndPoints(UsbInterface intf) {
		int nEndPoints = intf.getEndpointCount();
        for (int i = 0; i < intf.getEndpointCount(); i++) {
            UsbEndpoint ep = intf.getEndpoint(i);
            int eptype = ep.getType();
              if (ep.getType() == UsbConstants.USB_ENDPOINT_XFER_INT) {
                if (ep.getDirection() == UsbConstants.USB_DIR_OUT) {
                } else {
                	mEndpointIn = ep;
                	return true;
        return false;
    // Sets the current USB device and interface
    private boolean setUsbInterface(UsbDevice device, UsbInterface intf) {
        if (mDeviceConnection != null) {
            if (mInterface != null) {
                mDeviceConnection.releaseInterface(mInterface);
                mInterface = null;
            mDeviceConnection.close();
            mDevice = null;
            mDeviceConnection = null;
        if (device != null && intf != null) {
        	mManager.requestPermission(device, mPermissionIntent);
            UsbDeviceConnection connection = mManager.openDevice(device);
            if (connection != null) {
                if (connection.claimInterface(intf, true)) {
                    mDevice = device;
                    mDeviceConnection = connection;
                    mInterface = intf;
                    mWaiterThread.start();
                    return true;
                } else {
                    connection.close();
            } else {
        return false;
    public int bytesToInt(byte lsb, byte msb)
		int x = (((int)(msb) << 8) & 0xff00) | (((int)lsb) & 0x00ff);
		// Negative?
		if ((x & 0x8000) != 0) x |= 0xffff0000;
    	return x;
    private class WaiterThread extends Thread {
        public boolean mStop;
        public void run() {
        	while(true) {
        	 byte[] bytes = new byte[7];
        	  int TIMEOUT = 0;
        	  int length = 7;
        	  int result;
        	  result = mDeviceConnection.bulkTransfer(mEndpointIn, bytes, length, TIMEOUT);
        	  // Translation packet comes in before rotation packet.  Wait until you have both before
        	  // doing anything with the data
        	  if (bytes[0] == 1)  // Translation packet
        		  t[0] = bytesToInt(bytes[1], bytes[2]);
        		  t[1] = bytesToInt(bytes[3], bytes[4]);
        		  t[2] = bytesToInt(bytes[5], bytes[6]);
        	  else if (bytes[0] == 2)  // Rotation packet
        		  r[0] = bytesToInt(bytes[1], bytes[2]);
        		  r[1] = bytesToInt(bytes[3], bytes[4]);
        		  r[2] = bytesToInt(bytes[5], bytes[6]);
        		  String dataString = new String();
        		  dataString = String.format("t:%d %d %d   r: %d %d %d ", t[0],t[1],t[2],r[0],r[1],r[2]);
        		  log(dataString);
        	  else if (bytes[0] == 3)  // Button packet
    BroadcastReceiver mUsbReceiver = new BroadcastReceiver() {
        public void onReceive(Context context, Intent intent) {
            String action = intent.getAction();
            if (UsbManager.ACTION_USB_DEVICE_ATTACHED.equals(action)) {
                UsbDevice device = (UsbDevice)intent.getParcelableExtra(UsbManager.EXTRA_DEVICE);
            } else if (UsbManager.ACTION_USB_DEVICE_DETACHED.equals(action)) {
                UsbDevice device = intent.getParcelableExtra(UsbManager.EXTRA_DEVICE);
                String deviceName = device.getDeviceName();
                if (mDevice != null && mDevice.equals(deviceName)) {
            } else if (ACTION_USB_PERMISSION.equals(action)) {
                synchronized (this) {
                    if (intent.getBooleanExtra(UsbManager.EXTRA_PERMISSION_GRANTED, false)) {
                        if(device != null){
                    else {
robert_ugo
Re: Android support
Thanks a lot again! It will be very helpfull.
You are a great support!
robert_ugo
Re: Android support
It's me again.
I have been working with this code, but i can't get it working. My app can't find 3dconnexion device. I have some questions:
- Can i get a manifest.xml? It can be problem with permissions, but i can't find it.
- Did you connect 3dconnexion via any addition device or kit?
It would be great if you can share the whole source code of this example app (of course if you can do this).
I hope you can help me one more time.
Re: Android support
robert_ugo wrote: - Can i get a manifest.xml? It can be problem with permissions, but i can't find it.
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
    package="com.android.adb">
    <uses-feature android:name="android.hardware.usb.host" />
    <uses-sdk android:minSdkVersion="12" />
    <application>
        <activity android:name="AdbTestActivity" android:label="ADB Test">
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.DEFAULT" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
            <intent-filter>
                <action android:name="android.hardware.usb.action.USB_DEVICE_ATTACHED" />
            </intent-filter>
            <meta-data android:name="android.hardware.usb.action.USB_DEVICE_ATTACHED"
                android:resource="@xml/device_filter" />
        </activity>
    </application>
</manifest>
robert_ugo wrote:- Did you connect 3dconnexion via any addition device or kit?
Plugged it directly into an ASUS Slider.
robert_ugo wrote:It would be great if you can share the whole source code of this example app
I need to do an Android SDK. The code I have now is an experimental mess. I'll email it to you. Caveat Emptor.
robert_ugo
Re: Android support
Thanks for your help! Finally it was problem with tablet. I had to replace some system files and from now everything works :)
ligi
Re: Android support
Post by ligi »
just wanted to say thanks for the Question and the provided code snipped - used that at a hackathon to control a AR.Drone with a SpaceNavigator attached to a Nexus 7 - you can find the source here:
https://github.com/ligi/SpaceAR.Drone
and some more info here:
https://docs.google.com/presentation/d/ ... edit#slide
Re: Android support
Excellent. Let's see some video.
Re: Android support
Too cool! Video, please.
In your presentation, you may want to change the link to this topic to:
viewtopic.php?f=22&t=5339
ligi
Re: Android support
Post by ligi »
@ngomes: thanks - I just updated the link
@jwick @ngomes - will post a link to the videos once they are uploaded - we recorded with a HD-Cam - some small phone-videos are already in this stream: https://plus.google.com/u/0/events/c6dp ... cpufftkqtk - but I would wait for the HD-Videos
PS: any idea on how I could trigger the blue light inside the SpaceNavigator on Android?
Re: Android support
ligi wrote:PS: any idea on how I could trigger the blue light inside the SpaceNavigator on Android?
You can turn the LEDs on by sending the packet: 0x04 0x01. Turn them off with 0x04 0x00.
ligi
Re: Android support
Post by ligi »
thanks for the hint with 0x04 0x01, but I cannot find an endopoint to write to (ep.getDirection() == UsbConstants.USB_DIR_OUT)
ligi
Re: Android support
Post by ligi »
intf.getEndpointCount() returns 1 and this is UsbConstants.USB_DIR_IN - how can I send to the Device?
