3DxWare in Debian
Hello rob,
the problem (device in /dev/bus/usb instead of /proc/bus/usb)described in previous posts of this thread is solved with the current driver. Which is version 1.2.0 and available from our download site. Are you using this version?
Which error message do you get? Is it an error because of the missing lib or does the driver fail to find the device? Could you please post the message here?
Uta Ludwig
rob
Post by rob »
Hello Uta,
I use v1.0.2 but will install the 1.2.0 driver.
The message from 3dxsrv is: error while loading shared libraries: libXm.so.3: cannot open shared object file: no such file or directory
Thanks for the quick reply!
Rob
rob
Post by rob »
Hello again,
Tested driver version 1.2.0; this gives the same message regarding the libXm.so.3 file.
Maybe relevant is that I run Opensuse 10.2 in the 64 bit version?
Rob
This post could help ...
