Could not open USB port on RH EL 5.5 (32 bits)
krijnenr
Post by krijnenr »
After installing 3dxware 1.5.2 (32 bits) for my SpaceNavigator on Red Hat EL 5.5 (32 bits) it fails to start the driver (see log file below).
I'm starting the driver manually with /etc/3DxWare/daemon/3dxsrv -d usb
Any suggestions?
3DxWareUNIX V1.5.2 ID 5945 log file
Process ID: 3447
Time: 2010-11-12 18:42:54
Machineinfo 1: Systemname=Linux, Nodename=facpp12, Release=2.6.18-194.el5PAE
Machineinfo 2: Version=#1 SMP Tue Mar 16 22:00:21 EDT 2010, Machine=i686
Runlevel-Info: run-level 5 Nov 12 18:42 last=S
[2010-11-12 18:42:54] uddev.c, 1198: UdDevInit() 0x821e008
[2010-11-12 18:42:54] 3dxsrv.c,806: displayname = $DISPLAY set to :0
[2010-11-12 18:42:54] 3dxsrv.c,811: putenv() was successful
[2010-11-12 18:42:54] 3dxsrv.c,813: displayname is now :0
[2010-11-12 18:42:55] 3dxsrv.c :: startupInittab(), authGetUser(), failed to get user
[2010-11-12 18:42:55] Error: 3dxsrv.c :: startupInittab(), authGetUser(), failed to get user
[2010-11-12 18:43:01] auth.c :: authGetUser(), FOUND: user home = "/home/facsim"
[2010-11-12 18:43:01] 3dxsrv.c :: startupInittab(), authGetUser(), user=facsim
[2010-11-12 18:43:01] UdDev: Opening USB device on USB port /proc/bus/usb/002/003
[2010-11-12 18:43:01] Error: Could not open USB port or no supported device found! Exiting!
Re: Could not open USB port on RH EL 5.5 (32 bits)
Hello krijnenr,
the log files seems to be from a different start than the one you listed. Please make sure the start of the driver in the /etc/inittab is disabled. To do this you need root privileges. Either you delete the line or you change the word "respawn" in that line to "off". Launch a
  • init q
after that.
Then start the driver with this command:
  • /etc/3DxWare/daemon/3dxsrv -d usb -debug -E
Let us know what you get in the log file (/tmp/3DxWare.log)
krijnenr
Post by krijnenr »
Here is a log file when started manually.
Strange thing is that the Space mouse works on another RHEL5.5 system (comparable hardware (DELL M6500 laptop). However the working one has much more rpm's installed.
We also tested it with another Space mouse, having the same result. Looks like the driver is missing something
Se below for the different rpm lists.
Process ID: 4701
Time: 2010-11-15 13:02:26
Runlevel-Info: run-level 5 2010-11-15 11:26 last=S
[2010-11-15 13:02:26] uddev.c, 1198: UdDevInit() 0x8f74008
[2010-11-15 13:02:26] 3dxsrv.c,806: displayname = :0.0
[2010-11-15 13:02:26] auth.c :: authGetUser(), FOUND: user home = "/home/facsim"
[2010-11-15 13:02:26] 3dxsrv.c :: startupCommandLine(), authGetUser(), user=facsim
[2010-11-15 13:02:26] Error: Could not open USB port or no supported device found! Exiting!
RPM list on system with error:
AdobeReader_enu-9.3.4-1
Deployment_Guide-en-US-5.2-11
GConf2-2.14.0-9.el5
ImageMagick-6.2.8.0-4.el5_1.1
MAKEDEV-3.23-1.2
NetworkManager-0.7.0-10.el5
NetworkManager-glib-0.7.0-10.el5
NetworkManager-gnome-0.7.0-10.el5
ORBit2-2.14.3-5.el5
OpenIPMI-2.0.16-7.el5
OpenIPMI-libs-2.0.16-7.el5
OpenIPMI-tools-2.0.16-7.el5
PyQt-3.16-4
PyXML-0.8.4-4.el5_4.2
SysVinit-2.86-15.el5
a2ps-4.13b-57.2.el5
acl-2.2.39-6.el5
acpid-1.0.4-9.el5_4.2
alsa-lib-1.0.17-1.el5
alsa-utils-1.0.17-1.el5
amtu-1.0.6-1.el5
anacron-2.3-45.el5
antlr-2.7.6-4jpp.2
apmd-3.2.2-5
apr-1.2.7-11.el5_3.1
apr-util-1.2.7-11.el5
aspell-0.60.3-7.1
aspell-en-6.0-2.1
aspell-nl-0.1e-2.el5
at-3.1.8-84.el5
at-spi-1.7.11-3.el5
atk-1.12.2-1.fc6
attr-2.4.32-1.1
audiofile-0.2.6-5
audit-1.7.17-3.el5
audit-libs-1.7.17-3.el5
audit-libs-python-1.7.17-3.el5
authconfig-5.3.21-6.el5
authconfig-gtk-5.3.21-6.el5
autoconf-2.59-12
autofs-5.0.1-0.rc2.143.el5
automake-1.9.6-2.3.el5
automake14-1.4p6-13.el5.1
automake15-1.5-16.el5.2
automake16-1.6.3-8.el5.1
automake17-1.7.9-7.el5.2
avahi-0.6.16-7.el5
avahi-compat-libdns_sd-0.6.16-7.el5
avahi-glib-0.6.16-7.el5
basesystem-8.0-5.1.1
bash-3.2-24.el5
bc-1.06-21
bind-libs-9.3.6-4.P1.el5_4.2
bind-utils-9.3.6-4.P1.el5_4.2
binutils-2.17.50.0.6-14.el5
bison-2.3-2.1
bitmap-fonts-0.3-5.1.1
bitstream-vera-fonts-1.10-7
bluez-gnome-0.5-5.fc6
bluez-hcidump-1.32-1
bluez-libs-3.7-1.1
bluez-utils-3.7-2.2
brlapi-0.4.1-4.el5
busybox-1.2.0-7.el5
byacc-1.9-29.2.2
bzip2-1.0.3-4.el5_2
bzip2-libs-1.0.3-4.el5_2
cairo-1.2.4-5.el5
ccid-1.3.8-1.el5
cdparanoia-libs-alpha9.8-27.2
cdrdao-1.2.1-2
cdrecord-2.01-10.7.el5
checkpolicy-1.33.1-6.el5
chkconfig-1.3.30.2-2.el5
chkfontpath-1.10.1-1.1
compat-libgcc-296-2.96-138
compat-libstdc++-296-2.96-138
compat-libstdc++-33-3.2.3-61
comps-extras-11.1-1.1
conman-0.1.9.2-8.el5
control-center-2.16.0-16.el5
coolkey-1.1.0-14.el5
coreutils-5.97-23.el5_4.2
cpio-2.6-23.el5_4.1
cpp-4.1.2-48.el5
cpufreq-utils-005-1.el5
cpuspeed-1.2.1-9.el5
cracklib-2.8.9-3.3
cracklib-dicts-2.8.9-3.3
crash-4.1.2-4.el5
crontabs-1.10-8
crypto-utils-2.3-2.el5
cryptsetup-luks-1.0.3-5.el5
cscope-15.5-15.1.el5_3.1
ctags-5.6-1.1
cups-1.3.7-18.el5
cups-libs-1.3.7-18.el5
curl-7.15.5-9.el5
cvs-1.11.22-7.el5
cyrus-sasl-lib-2.1.22-5.el5_4.3
cyrus-sasl-md5-2.1.22-5.el5_4.3
cyrus-sasl-plain-2.1.22-5.el5_4.3
db4-4.3.29-10.el5
dbus-1.1.2-14.el5
dbus-glib-0.73-8.el5
dbus-libs-1.1.2-14.el5
dbus-python-0.70-9.el5_4
dbus-x11-1.1.2-14.el5
dejavu-lgc-fonts-2.10-1
desktop-backgrounds-basic-2.0-37
desktop-file-utils-0.10-7
desktop-printing-0.19-20.2.el5
dev86-0.16.17-2.2
device-mapper-1.02.39-1.el5
device-mapper-event-1.02.39-1.el5
device-mapper-multipath-0.4.7-34.el5
dhclient-3.0.5-23.el5
dhcpv6-client-1.0.10-18.el5
diffstat-1.41-1.2.3.el5
diffutils-2.8.1-15.2.3.el5
distcache-1.4.5-14.1
dmidecode-2.10-3.el5
dmraid-1.0.0.rc13-63.el5
dmraid-events-1.0.0.rc13-63.el5
dnsmasq-2.45-1.1.el5_3
docbook-dtds-1.0-30.1
dogtail-0.6.1-3.el5
dos2unix-3.1-27.2.el5
dosfstools-2.11-9.el5
doxygen-1.4.7-1.1
dump-0.4b41-4.el5
dvd+rw-tools-7.0-1.el5
e2fsprogs-1.39-23.el5
e2fsprogs-libs-1.39-23.el5
ed-0.2-39.el5_2
eel2-2.16.1-1.el5
eject-2.1.5-4.2.el5
elfutils-0.137-3.el5
elfutils-libelf-0.137-3.el5
elfutils-libs-0.137-3.el5
enscript-1.6.4-4.1.1.el5_2
esound-0.2.36-3
ethtool-6-4.el5
evince-0.6.0-13.el5
evolution-data-server-1.12.3-18.el5
exim-4.63-5.el5
expat-1.95.8-8.3.el5_4.2
fbset-2.1-22
festival-1.95-5.2.1
file-4.17-15.el5_3.1
filesystem-2.4.0-3.el5
findutils-4.2.27-6.el5
fipscheck-1.2.0-1.el5
fipscheck-lib-1.2.0-1.el5
firefox-3.0.18-1.el5_4
firstboot-1.4.27.8-1.el5
firstboot-tui-1.4.27.8-1.el5
flac-1.1.2-28.el5_0.1
flash-plugin-10.1.82.76-release
flex-2.5.4a-41.fc6
fontconfig-2.4.1-7.el5
foomatic-3.0.2-38.3.el5
freeglut-2.4.0-7.1.el5
freetype-2.2.1-21.el5_3
ftp-0.17-35.el5
gail-1.9.2-3.el5
gamin-0.1.7-8.el5
gamin-python-0.1.7-8.el5
gawk-3.1.5-14.el5
gcalctool-5.8.25-1.el5
gcc-4.1.2-48.el5
gcc-c++-4.1.2-48.el5
gd-2.0.33-9.4.el5_4.2
gdb-7.0.1-23.el5
gdbm-1.8.0-26.2.1
gdk-pixbuf-0.22.0-25.el5
gdm-2.16.0-56.el5
gedit-2.16.0-9.el5
gettext-0.14.6-4.el5
ghostscript-8.15.2-9.11.el5
ghostscript-fonts-5.50-13.1.1
gimp-2.2.13-2.0.7.el5
gimp-help-2-0.1.0.10.1.1
gimp-libs-2.2.13-2.0.7.el5
gimp-print-4.2.7-22.2.el5
gimp-print-plugin-4.2.7-22.2.el5
gimp-print-utils-4.2.7-22.2.el5
gjdoc-0.7.7-12.el5
glib-1.2.10-20.el5
glib2-2.12.3-4.el5_3.1
glibc-2.5-49
glibc-common-2.5-49
glibc-devel-2.5-49
glibc-headers-2.5-49
glx-utils-6.5.1-7.8.el5
gmp-4.1.4-10.el5
gnome-applets-2.16.0.1-19.el5
gnome-audio-2.0.0-3.1.1
gnome-backgrounds-2.15.92-1.fc6
gnome-bluetooth-0.7.0-10.2.el5
gnome-bluetooth-libs-0.7.0-10.2.el5
gnome-desktop-2.16.0-1.fc6
gnome-doc-utils-0.8.0-2.fc6
gnome-icon-theme-2.16.0.1-4.el5
gnome-keyring-0.6.0-1.fc6
gnome-mag-0.13.1-1.fc6
gnome-media-2.16.1-3.el5
gnome-menus-2.16.0-2.fc6
gnome-mime-data-2.4.2-3.1
gnome-mount-0.5-3.el5
gnome-netstatus-2.12.0-5.el5
gnome-panel-2.16.1-7.el5
gnome-pilot-2.0.13-16
gnome-power-manager-2.16.0-10.el5
gnome-python2-2.16.0-1.fc6
gnome-python2-applet-2.16.0-3.el5
gnome-python2-bonobo-2.16.0-1.fc6
gnome-python2-canvas-2.16.0-1.fc6
gnome-python2-desktop-2.16.0-3.el5
gnome-python2-extras-2.14.2-6.el5
gnome-python2-gconf-2.16.0-1.fc6
gnome-python2-gnomeprint-2.16.0-3.el5
gnome-python2-gnomevfs-2.16.0-1.fc6
gnome-python2-gtkhtml2-2.14.2-6.el5
gnome-python2-gtksourceview-2.16.0-3.el5
gnome-python2-libegg-2.14.2-6.el5
gnome-screensaver-2.16.1-8.el5
gnome-session-2.16.0-7.el5
gnome-speech-0.4.5-1.fc6
gnome-system-monitor-2.16.0-3.el5
gnome-terminal-2.16.0-5.3.el5
gnome-themes-2.16.0-1.fc6
gnome-user-docs-2.16.0-2.fc6
gnome-user-share-0.10-6.el5
gnome-utils-2.16.0-5.el5
gnome-vfs2-2.16.2-6.el5
gnome-vfs2-smb-2.16.2-6.el5
gnome-volume-manager-2.15.0-5.el5
gnu-efi-3.0c-1.1
gnupg-1.4.5-14
gnutls-1.4.1-3.el5_3.5
gok-1.2.0-2.el5
gphoto2-2.2.0-3.el5
gpm-1.20.1-74.1
grep-2.5.1-55.el5
groff-1.18.1.1-11.1
grub-0.97-13.5
gstreamer-0.10.20-3.el5
gstreamer-plugins-base-0.10.20-3.0.1.el5_3
gstreamer-plugins-good-0.10.9-1.el5_3.2
gstreamer-tools-0.10.20-3.el5
gthumb-2.7.8-8.el5
gtk+-1.2.10-56.el5
gtk2-2.10.4-20.el5
gtk2-engines-2.8.0-3.el5
gtkhtml2-2.11.0-3
gtksourceview-1.8.0-1.fc6
gtkspell-2.0.11-2.1
gucharmap-1.8.0-1.fc6
gzip-1.3.5-11.el5_4.1
hal-0.5.8.1-59.el5
hal-cups-utils-0.6.2-5.2.el5
hdparm-6.6-2
hesiod-3.1.0-8
hicolor-icon-theme-0.9-2.1
hmaccalc-0.9.6-3.el5
hpijs-1.6.7-4.1.el5_2.4
hplip-1.6.7-4.1.el5_2.4
htmlview-4.0.0-2.el5
httpd-2.2.3-43.el5
httpd-manual-2.2.3-43.el5
hwdata-0.213.18-1.el5.1
icewm-0.9.2-2
ifd-egate-0.05-15
im-chooser-0.3.3-6.el5
imake-1.0.2-3
indent-2.2.9-14.fc6
info-4.8-14.el5
initscripts-8.45.30-2.el5
iproute-2.6.18-11.el5
ipsec-tools-0.6.5-13.el5_3.1
iptables-1.3.5-5.3.el5_4.1
iptables-ipv6-1.3.5-5.3.el5_4.1
iptstate-1.4-2.el5
iputils-20020927-46.el5
irda-utils-0.9.17-2.fc6
irqbalance-0.55-15.el5
iwl5000-firmware-5.4.A.11-2
java-1.4.2-gcj-compat-1.4.2.0-40jpp.115
joystick-1.2.15-20.2.2
jpackage-utils-1.7.3-1jpp.2.el5
jre-1.6.0_21-fcs
jwhois-3.2.3-8.el5
kbd-1.12-21.el5
kernel-PAE-2.6.18-194.el5
kernel-PAE-devel-2.6.18-194.el5
kernel-headers-2.6.18-194.el5
kexec-tools-1.102pre-96.el5
keyutils-libs-1.2-1.el5
kpartx-0.4.7-34.el5
krb5-auth-dialog-0.7-1
krb5-libs-1.6.1-36.el5_4.1
krb5-workstation-1.6.1-36.el5_4.1
ksh-20100202-1.el5
kudzu-1.2.57.1.24-1
launchmail-4.0.0-2.el5
lcms-1.18-0.1.beta1.el5_3.2
less-436-2.el5
lftp-3.7.11-4.el5
libFS-1.0.0-3.1
libICE-1.0.1-2.1
libIDL-0.8.7-1.fc6
libSM-1.0.1-3.1
libX11-1.0.3-11.el5
libXScrnSaver-1.1.0-3.1
libXTrap-1.0.0-3.1
libXau-1.0.1-3.1
libXaw-1.0.2-8.1
libXcursor-1.1.7-1.1
libXdamage-1.0.3-2.1
libXdmcp-1.0.1-2.1
libXevie-1.0.1-3.1
libXext-1.0.1-2.1
libXfixes-4.0.1-2.1
libXfont-1.2.2-1.0.3.el5_1
libXfontcache-1.0.2-3.1
libXft-2.1.10-1.1
libXi-1.0.1-4.el5_4
libXinerama-1.0.1-2.1
libXmu-1.0.2-5
libXp-1.0.0-8.1.el5
libXpm-3.5.5-3
libXrandr-1.1.1-3.3
libXrender-0.9.1-3.1
libXres-1.0.1-3.1
libXt-1.0.2-3.2.el5
libXtst-1.0.1-3.1
libXv-1.0.1-4.1
libXxf86dga-1.0.1-3.1
libXxf86misc-1.0.1-3.1
libXxf86vm-1.0.1-3.1
libacl-2.2.39-6.el5
libaio-0.3.106-5
libao-0.8.6-7
libart_lgpl-2.3.17-4
libattr-2.4.32-1.1
libavc1394-0.5.3-1.fc6
libbonobo-2.16.0-1.fc6
libbonoboui-2.16.0-1.fc6
libbtctl-0.6.0-9.2.el5
libcap-1.10-26
libcroco-0.6.1-2.1
libdaemon-0.10-5.el5
libdmx-1.0.2-3.1
libdrm-2.0.2-1.1
libdv-0.104-4.fc6.1
liberation-fonts-1.0-1.el5
libevent-1.4.13-1
libexif-0.6.13-4.0.2.el5_1.1
libfontenc-1.0.2-2.2.el5
libgail-gnome-1.1.3-1.2.1
libgcc-4.1.2-48.el5
libgcj-4.1.2-48.el5
libgcrypt-1.4.4-5.el5
libglade2-2.6.0-2
libgnome-2.16.0-6.el5
libgnomecanvas-2.14.0-4.1
libgnomecups-0.2.2-9
libgnomeprint22-2.12.1-10.el5
libgnomeprintui22-2.12.1-6
libgnomeui-2.16.0-5.el5
libgomp-4.4.0-6.el5
libgpg-error-1.4-2
libgsf-1.14.1-6.1
libgssapi-0.10-2
libgtop2-2.14.4-8.el5_4
libhugetlbfs-1.3-7.el5
libidn-0.6.5-1.1
libiec61883-1.0.0-11.fc6
libjpeg-6b-37
libmng-1.0.9-5.1
libnotify-0.4.2-6.el5
libogg-1.1.3-3.el5
liboil-0.3.8-2.1
libpcap-0.9.4-15.el5
libpng-1.2.10-7.1.el5_3.2
libpurple-2.6.6-1.el5
libraw1394-1.3.0-1.el5
librsvg2-2.16.1-1.el5
libselinux-1.33.4-5.5.el5
libselinux-python-1.33.4-5.5.el5
libselinux-utils-1.33.4-5.5.el5
libsemanage-1.9.1-4.4.el5
libsepol-1.15.2-3.el5
libsilc-1.0.2-2.fc6
libsmbclient-3.0.33-3.28.el5
libsoup-2.2.98-2.el5_3.1
libstdc++-4.1.2-48.el5
libstdc++-devel-4.1.2-48.el5
libsysfs-2.0.0-6
libtermcap-2.0.8-46.1
libtheora-1.0alpha7-1
libtiff-3.8.2-7.el5_3.4
libtool-1.5.22-7.el5_4
libusb-0.1.12-5.1
libuser-0.54.7-2.1.el5_4.1
libutempter-1.1.4-4.el5
libvolume_id-095-14.21.el5
libvorbis-1.1.2-3.el5_4.4
libwmf-0.2.8.4-10.2
libwnck-2.16.0-4.fc6
libxkbfile-1.0.3-3.1
libxklavier-3.0-3.el5
libxml2-2.6.26-2.1.2.8
libxml2-python-2.6.26-2.1.2.8
libxslt-1.1.17-2.el5_2.2
linuxwacom-0.7.8.3-8.el5
lockdev-1.0.1-10
logrotate-3.7.4-9
logwatch-7.3-8.el5
lsof-4.78-3
ltrace-0.5-13.45svn.el5
lvm2-2.02.56-8.el5
m2crypto-0.16-6.el5.6
m4-1.4.5-3.el5.1
mailcap-2.1.23-1.fc6
mailx-8.1.1-44.2.2
make-3.81-3.el5
man-1.6d-1.1
man-pages-2.39-15.el5
mcstrans-0.2.11-3.el5
mdadm-2.6.9-3.el5
meanwhile-1.0.2-5.el5
mesa-libGL-6.5.1-7.8.el5
mesa-libGLU-6.5.1-7.8.el5
metacity-2.16.0-15.el5
mgetty-1.1.33-9.fc6
microcode_ctl-1.17-1.50.el5
mingetty-1.07-5.2.2
mkbootdisk-1.5.3-2.1
mkinitrd-5.1.19.6-61
mkisofs-2.01-10.7.el5
mktemp-1.5-23.2.2
mlocate-0.15-1.el5.2
mod_perl-2.0.4-6.el5
mod_python-3.2.8-3.1
mod_ssl-2.2.3-43.el5
module-init-tools-3.3-0.pre3.1.60.el5
mtools-3.9.10-2.fc6
mtr-0.71-3.1
mysql-5.0.77-4.el5_4.2
nano-1.3.12-1.1
nash-5.1.19.6-61
nautilus-2.16.2-7.el5
nautilus-cd-burner-2.16.0-7.el5
nautilus-extensions-2.16.2-7.el5
nautilus-sendto-1.0.1-6.el5
nc-1.84-10.fc6
ncurses-5.5-24.20060715
nedit-5.5-21.el5
neon-0.25.5-10.el5_4.1
net-snmp-libs-5.3.2.2-9.el5
net-tools-1.60-81.el5
netpbm-10.35.58-8.el5
netpbm-progs-10.35.58-8.el5
newt-0.52.2-15.el5
newt-perl-1.08-9.2.2
nfs-utils-1.0.9-44.el5
nfs-utils-lib-1.0.8-7.6.el5
nmap-4.11-1.1
notification-daemon-0.3.5-9.el5
notify-python-0.1.0-3.fc6
nscd-2.5-49
nspluginwrapper-1.3.0-8.el5
nspr-4.7.6-1.el5_4
nss-3.12.3.99.3-1.el5_3.2
nss-tools-3.12.3.99.3-1.el5_3.2
nss_db-2.2-35.3
nss_ldap-253-25.el5
ntp-4.2.2p1-9.el5_4.1
ntsysv-1.3.30.2-2.el5
numactl-0.9.8-11.el5
oddjob-0.27-9.el5
oddjob-libs-0.27-9.el5
openjade-1.3.2-27
openldap-2.3.43-12.el5
openldap-clients-2.3.43-12.el5
openmotif-2.3.1-2.el5_4.1
openmotif22-2.2.3-18
openobex-1.3-3.1
opensp-1.5.2-4
openssh-4.3p2-41.el5
openssh-askpass-4.3p2-41.el5
openssh-clients-4.3p2-41.el5
openssh-server-4.3p2-41.el5
openssl-0.9.8e-12.el5_4.6
openssl097a-0.9.7a-9.el5_2.1
oprofile-0.9.4-15.el5
orca-1.0.0-5.el5
pam-0.99.6.2-6.el5_4.1
pam_ccreds-3-5
pam_krb5-2.2.14-15
pam_passwdqc-1.0.2-1.2.2
pam_pkcs11-0.5.3-23
pam_smb-1.1.7-7.2.1
pango-1.14.9-6.el5
paps-0.6.6-19.el5
parted-1.8.1-27.el5
passwd-0.73-1
patch-2.5.4-29.2.3.el5
patchutils-0.2.31-2.2.2
pax-3.4-2.el5
pciutils-2.2.3-8.el5
pcmciautils-014-5
pcre-6.6-2.el5_1.7
pcsc-lite-1.4.4-1.el5
pcsc-lite-libs-1.4.4-1.el5
perl-5.8.8-27.el5
perl-BSD-Resource-1.28-1.fc6.1
perl-DBI-1.52-2.el5
perl-String-CRC32-1.4-2.fc6
perl-URI-1.35-3
php-5.1.6-27.el5
php-cli-5.1.6-27.el5
php-common-5.1.6-27.el5
php-ldap-5.1.6-27.el5
pidgin-2.6.6-1.el5
pilot-link-0.11.8-16
pinfo-0.6.9-1.fc6
pirut-1.3.28-17.el5
pkgconfig-0.21-2.el5
pkinit-nss-0.7.6-1.el5
pm-utils-0.99.3-10.el5
policycoreutils-1.33.12-14.8.el5
policycoreutils-gui-1.33.12-14.8.el5
poppler-0.5.4-4.4.el5_4.11
poppler-utils-0.5.4-4.4.el5_4.11
popt-1.10.2.3-18.el5
portmap-4.0-65.2.2.1
postgresql-libs-8.1.18-2.el5_4.1
ppp-2.4.4-2.el5
prelink-0.4.0-2.el5
procps-3.2.7-16.el5
psacct-6.3.2-44.el5
psmisc-22.2-7
pstack-1.2-7.2.2
psutils-1.17-26.1
pyOpenSSL-0.6-1.p24.7.2.2
pycairo-1.2.0-1.1
pygobject2-2.12.1-5.el5
pygtk2-2.10.1-12.el5
pygtk2-libglade-2.10.1-12.el5
pykickstart-0.43.8-1.el5
pyorbit-2.14.1-3.el5
pyspi-0.6.1-1.el5
python-2.4.3-27.el5
python-dmidecode-3.10.8-4.el5
python-elementtree-1.2.6-5
python-iniparse-0.2.3-4.el5
python-ldap-2.2.0-2.1
python-numeric-23.7-2.2.2
python-sqlite-1.1.7-1.2.1
python-urlgrabber-3.1.0-5.el5
pyxf86config-0.3.31-2.fc6
qt-3.3.6-23.el5
quota-3.13-1.2.5.el5
rcs-5.7-30.1
rdate-1.4-8.el5
rdist-6.1.5-44
readahead-1.3-8.el5
readline-5.1-3.el5
redhat-artwork-5.0.9-2.el5
redhat-logos-4.9.16-1
redhat-lsb-3.1-12.3.EL
redhat-menus-6.7.8-3.el5
redhat-release-5Client-5.5.0.2
redhat-release-notes-5Client-31
redhat-rpm-config-8.0.45-32.el5
rhel-instnum-1.0.9-1.el5
rhgb-0.16.4-8.el5
rhn-check-0.4.20-33.el5
rhn-client-tools-0.4.20-33.el5
rhn-setup-0.4.20-33.el5
rhn-setup-gnome-0.4.20-33.el5
rhnlib-2.5.22-3.el5
rhnsd-4.7.0-5.el5
rhpl-0.194.1-1
rhpxl-0.41.1-9.el5
rmt-0.4b41-4.el5
rng-utils-2.0-1.14.1.fc6
rootfiles-8.1-1.1.1
rp-pppoe-3.5-32.1
rpm-4.4.2.3-18.el5
rpm-build-4.4.2.3-18.el5
rpm-libs-4.4.2.3-18.el5
rpm-python-4.4.2.3-18.el5
rsh-0.17-40.el5
rsync-2.6.8-3.1
sabayon-2.12.4-6.el5
sabayon-apply-2.12.4-6.el5
samba-client-3.0.33-3.28.el5
samba-common-3.0.33-3.28.el5
screen-4.0.3-1.el5_4.1
scrollkeeper-0.3.14-9.el5
sed-4.1.5-5.fc6
selinux-policy-2.4.6-279.el5
selinux-policy-devel-2.4.6-279.el5
selinux-policy-targeted-2.4.6-279.el5
setarch-2.0-1.1
setools-3.0-3.el5
setroubleshoot-2.0.5-5.el5
setroubleshoot-plugins-2.0.4-2.el5
setroubleshoot-server-2.0.5-5.el5
setserial-2.17-19.2.2
setup-2.5.58-7.el5
setuptool-1.19.2-1
sgml-common-0.6.3-18
sgpio-1.2.0_10-2.el5
shadow-utils-4.0.17-15.el5
shared-mime-info-0.19-5.el5
sip-4.4.5-3
slang-2.0.6-4.el5
smartmontools-5.38-2.el5
sos-1.7-9.49.el5
sox-12.18.1-1
specspo-13-1.el5
speex-1.0.5-4.el5_1.1
splint-3.1.1-16.el5
sqlite-3.3.6-5
squid-2.6.STABLE21-6.el5
startup-notification-0.8-4.1
strace-4.5.18-5.el5_4.1
stunnel-4.15-2.el5.1
subversion-1.4.2-4.el5_3.1
sudo-1.7.2p1-5.el5
svrcore-4.0.4-3.el5
swig-1.3.29-2.el5
symlinks-1.2-24.2.2
synaptics-0.14.4-8.fc6
sysfsutils-2.0.0-6
sysklogd-1.4.1-46.el5
syslinux-3.11-4
system-config-date-1.8.12-4.el5
system-config-display-1.0.48-2.el5
system-config-kdump-1.0.14-4.el5
system-config-keyboard-1.2.11-1.el5
system-config-kickstart-2.6.19.8-2.el5
system-config-language-1.1.18-3.el5
system-config-lvm-1.1.5-4.el5
system-config-network-1.3.99.18-1.el5
system-config-network-tui-1.3.99.18-1.el5
system-config-printer-0.7.32.10-1.el5
system-config-printer-libs-0.7.32.10-1.el5
system-config-rootpassword-1.1.9.1-1
system-config-securitylevel-1.6.29.1-5.el5
system-config-securitylevel-tui-1.6.29.1-5.el5
system-config-services-0.9.4-5.el5
system-config-soundcard-2.0.6-1.el5
system-config-users-1.2.51-4.el5
system-switch-java-1.1.2-2.el5_1
systemtap-1.1-3.el5
systemtap-runtime-1.1-3.el5
talk-0.17-29.2.2
tar-1.15.1-30.el5
tcl-8.4.13-4.el5
tcp_wrappers-7.6-40.7.el5
tcpdump-3.9.4-15.el5
tcsh-6.14-17.el5
telnet-0.17-39.el5
termcap-5.5-1.20060701.1
texinfo-4.8-14.el5
time-1.7-27.2.2
tk-8.4.13-5.el5_1.1
tmpwatch-2.9.7-1.1.el5.2
traceroute-2.0.1-5.el5
tree-1.5.0-4
ttmkfdir-3.0.9-23.el5
tux-3.2.18-9.fc6
tzdata-2010e-1.el5
udev-095-14.21.el5
udftools-1.0.0b3-0.1.el5
unix2dos-2.2-26.2.3.el5
unzip-5.52-3.el5
urw-fonts-2.3-6.1.1
usbutils-0.71-2.1
usermode-1.88-3.el5.2
usermode-gtk-1.88-3.el5.2
util-linux-2.13-0.52.el5_4.1
valgrind-3.5.0-1.el5
vconfig-1.9-3
vim-common-7.0.109-6.el5
vim-enhanced-7.0.109-6.el5
vim-minimal-7.0.109-6.el5
vixie-cron-4.1-77.el5_4.1
vnc-4.1.2-14.el5_3.1
vnc-server-4.1.2-14.el5_3.1
vorbis-tools-1.1.1-3.el5
vte-0.14.0-2.el5
wdaemon-0.14-5
webalizer-2.01_10-30.1
wget-1.11.4-2.el5_4.1
which-2.16-7
wireless-tools-28-2.el5
words-3.0-9.1
wpa_supplicant-0.5.10-9.el5
xdelta-1.1.3-20
xkeyboard-config-0.8-9.el5
xml-common-0.6.3-18
xorg-x11-apps-7.1-4.0.1.el5
xorg-x11-drivers-7.1-4.2.el5
xorg-x11-drv-acecad-1.1.0-2.1
xorg-x11-drv-aiptek-1.0.1-2
xorg-x11-drv-apm-1.1.1-2.1
xorg-x11-drv-ark-0.6.0-2.1
xorg-x11-drv-ast-0.89.9-1.el5
xorg-x11-drv-ati-6.6.3-3.27.el5
xorg-x11-drv-calcomp-1.1.0-1.1
xorg-x11-drv-chips-1.1.1-2.1
xorg-x11-drv-cirrus-1.1.0-2.fc6
xorg-x11-drv-citron-2.2.0-1.1
xorg-x11-drv-cyrix-1.1.0-4
xorg-x11-drv-digitaledge-1.1.0-1.1
xorg-x11-drv-dmc-1.1.0-2
xorg-x11-drv-dummy-0.2.0-2.1
xorg-x11-drv-dynapro-1.1.0-2
xorg-x11-drv-elo2300-1.1.0-1.1
xorg-x11-drv-elographics-1.1.0-1.1
xorg-x11-drv-evdev-1.0.0.5-5.el5
xorg-x11-drv-fbdev-0.3.0-3
xorg-x11-drv-fpit-1.1.0-1.1
xorg-x11-drv-glint-1.1.1-4.1
xorg-x11-drv-hyperpen-1.1.0-2
xorg-x11-drv-i128-1.2.0-4
xorg-x11-drv-i740-1.1.0-2.1
xorg-x11-drv-i810-1.6.5-9.36.el5
xorg-x11-drv-jamstudio-1.1.0-1.1
xorg-x11-drv-joystick-1.1.0-1.1
xorg-x11-drv-keyboard-1.1.0-3
xorg-x11-drv-magellan-1.1.0-1.1
xorg-x11-drv-magictouch-1.0.0.5-2.1
xorg-x11-drv-mga-1.4.10-7.el5
xorg-x11-drv-microtouch-1.1.0-1.1
xorg-x11-drv-mouse-1.1.1-1.1
xorg-x11-drv-mutouch-1.1.0-3
xorg-x11-drv-neomagic-1.1.1-2.1
xorg-x11-drv-nsc-2.8.1-2.1
xorg-x11-drv-nv-2.1.15-3.el5
xorg-x11-drv-palmax-1.1.0-1.1
xorg-x11-drv-penmount-1.1.0-2.1
xorg-x11-drv-qxl-0.0.12-1.2.el5
xorg-x11-drv-rendition-4.1.0-3.1
xorg-x11-drv-s3-0.4.1-2.1
xorg-x11-drv-s3virge-1.9.1-2.1
xorg-x11-drv-savage-2.1.1-5.fc6
xorg-x11-drv-siliconmotion-1.4.1-2.1
xorg-x11-drv-sis-0.9.1-7.1.el5
xorg-x11-drv-sisusb-0.8.1-4.1
xorg-x11-drv-spaceorb-1.1.0-1.1
xorg-x11-drv-summa-1.1.0-1.1
xorg-x11-drv-tdfx-1.2.1-3.1
xorg-x11-drv-tek4957-1.1.0-1.1
xorg-x11-drv-trident-1.2.1-3.fc6
xorg-x11-drv-tseng-1.1.0-3.1
xorg-x11-drv-ur98-1.1.0-1.1
xorg-x11-drv-v4l-0.1.1-4
xorg-x11-drv-vesa-1.3.0-8.2.el5
xorg-x11-drv-vga-4.1.0-2.1
xorg-x11-drv-via-0.2.1-9
xorg-x11-drv-vmmouse-12.4.0-2.1
xorg-x11-drv-vmware-10.13.0-2.1
xorg-x11-drv-void-1.1.0-3.1
xorg-x11-drv-voodoo-1.1.0-3.1
xorg-x11-filesystem-7.1-2.fc6
xorg-x11-font-utils-7.1-2
xorg-x11-fonts-100dpi-7.1-2.1.el5
xorg-x11-fonts-75dpi-7.1-2.1.el5
xorg-x11-fonts-ISO8859-1-100dpi-7.1-2.1.el5
xorg-x11-fonts-ISO8859-1-75dpi-7.1-2.1.el5
xorg-x11-fonts-Type1-7.1-2.1.el5
xorg-x11-fonts-base-7.1-2.1.el5
xorg-x11-fonts-misc-7.1-2.1.el5
xorg-x11-fonts-truetype-7.1-2.1.el5
xorg-x11-server-Xnest-1.1.1-48.76.el5
xorg-x11-server-Xorg-1.1.1-48.76.el5
xorg-x11-server-Xvfb-1.1.1-48.76.el5
xorg-x11-server-utils-7.1-4.fc6
xorg-x11-twm-1.0.1-3.1
xorg-x11-utils-7.1-2.fc6
xorg-x11-xauth-1.0.1-2.1
xorg-x11-xfs-1.0.2-4
xorg-x11-xinit-1.0.2-15.el5
xorg-x11-xkb-utils-1.0.2-2.1
xsri-2.1.0-10.fc6
xterm-215-8.el5_4.1
xulrunner-1.9.0.18-1.el5_4
xxdiff-2.9.2-1
yelp-2.16.0-22.el5
yp-tools-2.9-1.el5
ypbind-1.19-12.el5
yum-3.2.22-26.el5
yum-metadata-parser-1.1.2-3.el5
yum-rhn-plugin-0.5.4-15.el5
yum-security-1.1.16-13.el5
yum-updatesd-0.9-2.el5
zenity-2.16.0-2.el5
zip-2.31-2.el5
zisofs-tools-1.0.6-3.2.2
zlib-1.2.3-3
zsh-4.2.6-3.el5
RPM list on system with working mouse:
a2ps-4.13b-57.2.el5
acl-2.2.39-6.el5
alacarte-0.10.0-1.fc6
alsa-lib-devel-1.0.17-1.el5
amtu-1.0.6-1.el5
anacron-2.3-45.el5
ant-1.6.5-2jpp.2
antlr-2.7.6-4jpp.2
apmd-3.2.2-5
aspell-0.60.3-7.1
aspell-en-6.0-2.1
at-3.1.8-84.el5
atk-1.12.2-1.fc6
atk-devel-1.12.2-1.fc6
at-spi-1.7.11-3.el5
at-spi-devel-1.7.11-3.el5
attr-2.4.32-1.1
audiofile-0.2.6-5
audiofile-devel-0.2.6-5
audit-1.7.17-3.el5
autoconf-2.59-12
avahi-0.6.16-7.el5
axis-1.2.1-2jpp.6
bash-3.2-24.el5
bc-1.06-21
bcel-5.1-8jpp.1
bison-2.3-2.1
bluez-libs-3.7-1.1
bluez-utils-3.7-2.2
brlapi-0.4.1-4.el5
bsf-2.3.0-11jpp.1
bsh-1.3.0-9jpp.1
bug-buddy-2.16.0-2.el5
busybox-1.2.0-7.el5
byacc-1.9-29.2.2
bzip2-1.0.3-4.el5_2
bzip2-devel-1.0.3-4.el5_2
cairo-1.2.4-5.el5
cairo-devel-1.2.4-5.el5
cairo-java-1.0.5-3.fc6
ccid-1.3.8-1.el5
cdda2wav-2.01-10.7.el5
cdparanoia-alpha9.8-27.2
cdrdao-1.2.1-2
classpathx-jaf-1.0-9jpp.1
classpathx-mail-1.1.1-4jpp.2
compat-gcc-34-3.4.6-4
compat-gcc-34-c++-3.4.6-4
compat-glibc-2.3.4-2.26
compat-glibc-headers-2.3.4-2.26
compat-libcom_err-1.0-7
cpio-2.6-23.el5_4.1
cpp-4.1.2-48.el5
cracklib-2.8.9-3.3
crash-4.1.2-4.el5
crontabs-1.10-8
ctags-5.6-1.1
cups-1.3.7-18.el5
curl-7.15.5-9.el5
curl-devel-7.15.5-9.el5
cvs-1.11.22-7.el5
cyrus-sasl-2.1.22-5.el5_4.3
cyrus-sasl-devel-2.1.22-5.el5_4.3
db4-4.3.29-10.el5
db4-devel-4.3.29-10.el5
dbus-1.1.2-14.el5
dbus-devel-1.1.2-14.el5
dbus-glib-devel-0.73-8.el5
dcraw-0.0.20060521-1.1
ddd-3.3.11-14.el5.4
dev86-0.16.17-2.2
devhelp-0.12-20.el5
docbook-style-dsssl-1.79-4.1
docbook-style-xsl-1.69.1-5.1
docbook-utils-0.6.14-5.1
dogtail-0.6.1-3.el5
doxygen-1.4.7-1.1
dump-0.4b41-4.el5
e2fsprogs-devel-1.39-23.el5
eclipse-ecj-3.2.1-19.el5
ed-0.2-39.el5_2
eel2-2.16.1-1.el5
eel2-devel-2.16.1-1.el5
eject-2.1.5-4.2.el5
elfutils-libelf-devel-0.137-3.el5
elfutils-libelf-devel-static-0.137-3.el5
elinks-0.11.1-6.el5_4.1
eog-2.16.0.1-6.el5
esc-1.1.0-11.el5
esound-0.2.36-3
esound-devel-0.2.36-3
ethtool-6-4.el5
evince-0.6.0-13.el5
expat-devel-1.95.8-8.3.el5_4.2
fbset-2.1-22
festival-1.95-5.2.1
file-roller-2.16.0-2.fc6
finger-0.17-32.2.1.1
flex-2.5.4a-41.fc6
fontconfig-devel-2.4.1-7.el5
freetype-devel-2.2.1-21.el5_3
ftp-0.17-35.el5
gail-1.9.2-3.el5
gail-devel-1.9.2-3.el5
gamin-0.1.7-8.el5
gawk-3.1.5-14.el5
gcc-4.1.2-48.el5
gcc44-4.4.0-6.el5
gcc44-c++-4.4.0-6.el5
GConf2-2.14.0-9.el5
GConf2-devel-2.14.0-9.el5
gconf-editor-2.16.0-3.el5
gdb-7.0.1-23.el5
gdbm-1.8.0-26.2.1
gdbm-devel-1.8.0-26.2.1
gd-devel-2.0.33-9.4.el5_4.2
gdm-2.16.0-56.el5
gedit-2.16.0-9.el5
geronimo-specs-1.0-0.M2.2jpp.12
geronimo-specs-compat-1.0-0.M2.2jpp.12
gftp-2.0.18-3.2.2
giflib-4.1.3-7.1.el5_3.1
gimp-data-extras-2.0.1-1.1.1
gjdoc-0.7.7-12.el5
glade2-2.12.1-6.el5
glib2-devel-2.12.3-4.el5_3.1
glibc-2.5-49
glibc-common-2.5-49
glibc-devel-2.5-49
glib-java-0.2.6-3.fc6
gmp-4.1.4-10.el5
gmp-devel-4.1.4-10.el5
gnome-desktop-devel-2.16.0-1.fc6
gnome-games-2.16.0-2.el5
gnome-keyring-devel-0.6.0-1.fc6
gnome-keyring-manager-2.16.0-3.el5
gnome-panel-devel-2.16.1-7.el5
gnome-pilot-devel-2.0.13-16
gnome-vfs2-devel-2.16.2-6.el5
gnu-efi-3.0c-1.1
gnupg-1.4.5-14
gnuplot-4.0.0-14.el5
gok-1.2.0-2.el5
gphoto2-2.2.0-3.el5
gpm-1.20.1-74.1
gpm-devel-1.20.1-74.1
grep-2.5.1-55.el5
groff-1.18.1.1-11.1
grub-0.97-13.5
gthumb-2.7.8-8.el5
gtk2-2.10.4-20.el5
gtk2-devel-2.10.4-20.el5
gtk-doc-1.7-1.fc6
gtkhtml2-2.11.0-3
gtkspell-2.0.11-2.1
guile-1.8.0-8.20060831cvs
hal-0.5.8.1-59.el5
hal-devel-0.5.8.1-59.el5
hal-gnome-0.5.8.1-59.el5
hdparm-6.6-2
hesiod-3.1.0-8
hesiod-devel-3.1.0-8
hsqldb-1.8.0.9-1jpp.2
httpd-2.2.3-43.el5
hwbrowser-0.30-3.el5
ifd-egate-0.05-15
imake-1.0.2-3
indent-2.2.9-14.fc6
info-4.8-14.el5
iptstate-1.4-2.el5
iso-codes-0.53-1
jakarta-commons-beanutils-1.7.0-5jpp.1
jakarta-commons-collections-3.2-2jpp.3
jakarta-commons-daemon-1.0.1-6jpp.1
jakarta-commons-dbcp-1.2.1-7jpp.1
jakarta-commons-digester-1.7-5jpp.1
jakarta-commons-discovery-0.3-4jpp.1
jakarta-commons-el-1.0-7jpp.1
jakarta-commons-fileupload-1.0-6jpp.1
jakarta-commons-httpclient-3.0-7jpp.1
jakarta-commons-launcher-0.9-6jpp.1
jakarta-commons-logging-1.0.4-6jpp.1
jakarta-commons-modeler-1.1-8jpp.3.el5
jakarta-commons-pool-1.3-5jpp.1
jakarta-commons-validator-1.1.4-5jpp.1
jakarta-oro-2.0.8-3jpp.1
java-1.6.0-openjdk-1.6.0.0-1.7.b09.el5
java-1.6.0-openjdk-devel-1.6.0.0-1.7.b09.el5
jwhois-3.2.3-8.el5
kbd-1.12-21.el5
keyutils-libs-devel-1.2-1.el5
kpartx-0.4.7-34.el5
krb5-devel-1.6.1-36.el5_4.1
ksh-20100202-1.el5
kudzu-1.2.57.1.24-1
kudzu-devel-1.2.57.1.24-1
less-436-2.el5
lftp-3.7.11-4.el5
libacl-2.2.39-6.el5
libacl-devel-2.2.39-6.el5
libaio-0.3.106-5
libao-0.8.6-7
libart_lgpl-devel-2.3.17-4
libattr-2.4.32-1.1
libattr-devel-2.4.32-1.1
libbonobo-devel-2.16.0-1.fc6
libbonoboui-devel-2.16.0-1.fc6
libcap-1.10-26
libcap-devel-1.10-26
libcroco-0.6.1-2.1
libcroco-devel-0.6.1-2.1
libdmx-1.0.2-3.1
libdrm-2.0.2-1.1
libdrm-devel-2.0.2-1.1
libdv-0.104-4.fc6.1
libevent-1.4.13-1
libfontenc-devel-1.0.2-2.2.el5
libFS-1.0.0-3.1
libgcc-4.1.2-48.el5
libgcj-4.1.2-48.el5
libgcrypt-devel-1.4.4-5.el5
libglade2-2.6.0-2
libglade2-devel-2.6.0-2
libglade-java-2.12.5-3.fc6
libgnomecanvas-devel-2.14.0-4.1
libgnome-devel-2.16.0-6.el5
libgnome-java-2.12.4-3.fc6
libgnomeprint22-devel-2.12.1-10.el5
libgnomeprintui22-devel-2.12.1-6
libgnomeui-devel-2.16.0-5.el5
libgomp-4.4.0-6.el5
libgpg-error-1.4-2
libgpg-error-devel-1.4-2
libgpod-0.4.0-1.el5
libgsf-1.14.1-6.1
libgsf-devel-1.14.1-6.1
libgssapi-0.10-2
libgtk-java-2.8.7-3.el5
libgtop2-devel-2.14.4-8.el5_4
libICE-1.0.1-2.1
libICE-devel-1.0.1-2.1
libicu-3.6-5.11.4
libIDL-0.8.7-1.fc6
libIDL-devel-0.8.7-1.fc6
libidn-0.6.5-1.1
libidn-devel-0.6.5-1.1
libjpeg-6b-37
libjpeg-devel-6b-37
libmng-1.0.9-5.1
libmng-devel-1.0.9-5.1
libmusicbrainz-2.1.1-4.1
libogg-1.1.3-3.el5
libogg-devel-1.1.3-3.el5
liboil-0.3.8-2.1
libpng-devel-1.2.10-7.1.el5_3.2
librsvg2-devel-2.16.1-1.el5
libselinux-devel-1.33.4-5.5.el5
libsepol-devel-1.15.2-3.el5
libsilc-1.0.2-2.fc6
libSM-1.0.1-3.1
libSM-devel-1.0.1-3.1
libsmi-0.4.5-2.el5
libstdc++44-devel-4.4.0-6.el5
libsysfs-2.0.0-6
libtermcap-devel-2.0.8-46.1
libtiff-devel-3.8.2-7.el5_3.4
libtool-ltdl-1.5.22-7.el5_4
libusb-0.1.12-5.1
libusb-devel-0.1.12-5.1
libuser-devel-0.54.7-2.1.el5_4.1
libvorbis-devel-1.1.2-3.el5_4.4
libwmf-0.2.8.4-10.2
libwpd-0.8.7-3.el5
libX11-1.0.3-11.el5
libX11-devel-1.0.3-11.el5
libXau-1.0.1-3.1
libXau-devel-1.0.1-3.1
libXaw-1.0.2-8.1
libXaw-devel-1.0.2-8.1
libXcomposite-0.3-5.1
libXcomposite-devel-0.3-5.1
libXcursor-devel-1.1.7-1.1
libXdamage-devel-1.0.3-2.1
libXdmcp-1.0.1-2.1
libXdmcp-devel-1.0.1-2.1
libXevie-1.0.1-3.1
libXevie-devel-1.0.1-3.1
libXext-1.0.1-2.1
libXext-devel-1.0.1-2.1
libXfixes-4.0.1-2.1
libXfixes-devel-4.0.1-2.1
libXfontcache-devel-1.0.2-3.1
libXfont-devel-1.2.2-1.0.3.el5_1
libXft-2.1.10-1.1
libXft-devel-2.1.10-1.1
libXi-1.0.1-4.el5_4
libXi-devel-1.0.1-4.el5_4
libXinerama-devel-1.0.1-2.1
libxml2-devel-2.6.26-2.1.2.8
libXmu-1.0.2-5
libXmu-devel-1.0.2-5
libXp-1.0.0-8.1.el5
libXp-devel-1.0.0-8.1.el5
libXpm-3.5.5-3
libXpm-devel-3.5.5-3
libXrandr-1.1.1-3.3
libXrandr-devel-1.1.1-3.3
libXrender-devel-0.9.1-3.1
libXres-1.0.1-3.1
libXres-devel-1.0.1-3.1
libXScrnSaver-devel-1.1.0-3.1
libxslt-devel-1.1.17-2.el5_2.2
libXt-1.0.2-3.2.el5
libXt-devel-1.0.2-3.2.el5
libXTrap-1.0.0-3.1
libXTrap-devel-1.0.0-3.1
libXtst-1.0.1-3.1
libXtst-devel-1.0.1-3.1
libXv-1.0.1-4.1
libXv-devel-1.0.1-4.1
libXvMC-1.0.2-2.1
libXvMC-devel-1.0.2-2.1
libXxf86dga-devel-1.0.1-3.1
libXxf86misc-devel-1.0.1-3.1
libXxf86vm-devel-1.0.1-3.1
lockdev-1.0.1-10
lockdev-devel-1.0.1-10
log4cpp-1.0-9.el5
log4cpp-devel-1.0-9.el5
log4j-1.2.13-3jpp.2
logrotate-3.7.4-9
logwatch-7.3-8.el5
lsof-4.78-3
lucene-1.4.3-1jpp.16
lvm2-2.02.56-8.el5
m4-1.4.5-3.el5.1
mailx-8.1.1-44.2.2
make-3.81-3.el5
MAKEDEV-3.23-1.2
man-1.6d-1.1
mdadm-2.6.9-3.el5
mesa-libGL-devel-6.5.1-7.8.el5
mesa-libGLU-devel-6.5.1-7.8.el5
mesa-libGLw-6.5.1-7.8.el5
mesa-libGLw-devel-6.5.1-7.8.el5
mgetty-1.1.33-9.fc6
mingetty-1.07-5.2.2
mktemp-1.5-23.2.2
mozldap-6.0.5-1.el5
mtools-3.9.10-2.fc6
mtr-0.71-3.1
mx4j-3.0.1-6jpp.4
nano-1.3.12-1.1
nash-5.1.19.6-61
nautilus-open-terminal-0.6-7.el5
nc-1.84-10.fc6
ncurses-devel-5.5-24.20060715
nedit-5.5-21.el5
netpbm-devel-10.35.58-8.el5
newt-0.52.2-15.el5
newt-devel-0.52.2-15.el5
nmap-4.11-1.1
nscd-2.5-49
nspr-4.7.6-1.el5_4
nspr-devel-4.7.6-1.el5_4
nss_db-2.2-35.3
nss-devel-3.12.3.99.3-1.el5_3.2
nss_ldap-253-25.el5
oddjob-0.27-9.el5
openjade-1.3.2-27
openldap-devel-2.3.43-12.el5
openmotif-devel-2.3.1-2.el5_4.1
openobex-1.3-3.1
openoffice.org-calc-3.1.1-19.5.el5
openoffice.org-core-3.1.1-19.5.el5
openoffice.org-draw-3.1.1-19.5.el5
openoffice.org-graphicfilter-3.1.1-19.5.el5
openoffice.org-impress-3.1.1-19.5.el5
openoffice.org-langpack-nl-3.1.1-19.5.el5
openoffice.org-math-3.1.1-19.5.el5
openoffice.org-ure-3.1.1-19.5.el5
openoffice.org-writer-3.1.1-19.5.el5
openoffice.org-xsltfilter-3.1.1-19.5.el5
opensp-1.5.2-4
openssl-devel-0.9.8e-12.el5_4.6
ORBit2-2.14.3-5.el5
ORBit2-devel-2.14.3-5.el5
orca-1.0.0-5.el5
pam_ccreds-3-5
pam-devel-0.99.6.2-6.el5_4.1
pam_krb5-2.2.14-15
pam_pkcs11-0.5.3-23
pam_smb-1.1.7-7.2.1
pango-1.14.9-6.el5
pango-devel-1.14.9-6.el5
paps-0.6.6-19.el5
parted-1.8.1-27.el5
passwd-0.73-1
pax-3.4-2.el5
pciutils-devel-2.2.3-8.el5
pcmciautils-014-5
pcre-6.6-2.el5_1.7
pcsc-lite-devel-1.4.4-1.el5
perl-5.8.8-27.el5
perl-HTML-Parser-3.55-1.fc6
perl-HTML-Tagset-3.10-2.1.1
perl-SGMLSpm-1.03ii-16.2.1
perl-URI-1.35-3
php-5.1.6-27.el5
pidgin-2.6.6-1.el5
pilot-link-devel-0.11.8-16
pinfo-0.6.9-1.fc6
pirut-1.3.28-17.el5
ppp-2.4.4-2.el5
prelink-0.4.0-2.el5
procmail-3.22-17.1
procps-3.2.7-16.el5
psacct-6.3.2-44.el5
psmisc-22.2-7
pstack-1.2-7.2.2
psutils-1.17-26.1
pycairo-1.2.0-1.1
pycairo-devel-1.2.0-1.1
pygobject2-devel-2.12.1-5.el5
pygobject2-doc-2.12.1-5.el5
pygtk2-codegen-2.10.1-12.el5
pygtk2-devel-2.10.1-12.el5
pyparted-1.8.1-4.el5
PyQt-3.16-4
pyspi-0.6.1-1.el5
python-2.4.3-27.el5
python-devel-2.4.3-27.el5
qt-3.3.6-23.el5
rcs-5.7-30.1
rdate-1.4-8.el5
rdesktop-1.6.0-3
rdist-6.1.5-44
readahead-1.3-8.el5
readline-5.1-3.el5
readline-devel-5.1-3.el5
regexp-1.4-2jpp.2
rhgb-0.16.4-8.el5
rhnlib-2.5.22-3.el5
rhnsd-4.7.0-5.el5
rhpl-0.194.1-1
rhpxl-0.41.1-9.el5
rhythmbox-0.11.6-4.el5
rmt-0.4b41-4.el5
rootfiles-8.1-1.1.1
rpm-4.4.2.3-18.el5
rpm-devel-4.4.2.3-18.el5
rp-pppoe-3.5-32.1
rsh-0.17-40.el5
rsync-2.6.8-3.1
SDL-1.2.10-8.el5
SDL-devel-1.2.10-8.el5
sed-4.1.5-5.fc6
sendmail-8.13.8-8.el5
setarch-2.0-1.1
setools-3.0-3.el5
setup-2.5.58-7.el5
setuptool-1.19.2-1
sip-4.4.5-3
slang-2.0.6-4.el5
slang-devel-2.0.6-4.el5
sos-1.7-9.49.el5
sound-juicer-2.16.0-3.el5
sox-12.18.1-1
specspo-13-1.el5
splint-3.1.1-16.el5
sqlite-3.3.6-5
sqlite-devel-3.3.6-5
startup-notification-devel-0.8-4.1
struts-1.2.9-4jpp.5
sudo-1.7.2p1-5.el5
svrcore-4.0.4-3.el5
swig-1.3.29-2.el5
symlinks-1.2-24.2.2
sysfsutils-2.0.0-6
syslinux-3.11-4
systemtap-1.1-3.el5
talk-0.17-29.2.2
tar-1.15.1-30.el5
tcl-8.4.13-4.el5
tcsh-6.14-17.el5
telnet-0.17-39.el5
texinfo-4.8-14.el5
time-1.7-27.2.2
tk-8.4.13-5.el5_1.1
tomcat5-5.5.23-0jpp.7.el5_3.2
tomcat5-admin-webapps-5.5.23-0jpp.7.el5_3.2
tomcat5-common-lib-5.5.23-0jpp.7.el5_3.2
tomcat5-jasper-5.5.23-0jpp.7.el5_3.2
tomcat5-jsp-2.0-api-5.5.23-0jpp.7.el5_3.2
tomcat5-server-lib-5.5.23-0jpp.7.el5_3.2
tomcat5-servlet-2.4-api-5.5.23-0jpp.7.el5_3.2
totem-2.16.7-6.el5
totem-mozplugin-2.16.7-6.el5
tree-1.5.0-4
tux-3.2.18-9.fc6
tzdata-2010e-1.el5
udev-095-14.21.el5
units-1.85-1.2.2
unzip-5.52-3.el5
urw-fonts-2.3-6.1.1
usbutils-0.71-2.1
vconfig-1.9-3
vino-2.13.5-9.el5
vte-0.14.0-2.el5
wdaemon-0.14-5
which-2.16-7
wireshark-1.0.8-1.el5_3.1
wireshark-gnome-1.0.8-1.el5_3.1
words-3.0-9.1
wsdl4j-1.5.2-4jpp.1
xalan-j2-2.7.0-6jpp.1
Xaw3d-1.5E-10.1
Xaw3d-devel-1.5E-10.1
xdelta-1.1.3-20
xerces-j2-2.7.1-7jpp.2.el5_4.2
xml-common-0.6.3-18
xml-commons-1.3.02-0.b2.7jpp.10
xml-commons-apis-1.3.02-0.b2.7jpp.10
xml-commons-resolver-1.1-1jpp.12
xmlsec1-1.2.9-8.1.1
xmlsec1-devel-1.2.9-8.1.1
xorg-x11-proto-devel-7.1-13.el5
xorg-x11-util-macros-1.0.2-4.fc6
xorg-x11-xtrans-devel-1.0.1-1.1.fc6
xrestop-0.2-6.2.2
xsri-2.1.0-10.fc6
xterm-215-8.el5_4.1
xulrunner-devel-1.9.0.18-1.el5_4
xxdiff-2.9.2-1
yelp-2.16.0-22.el5
ypbind-1.19-12.el5
yp-tools-2.9-1.el5
yum-3.2.22-26.el5
zenity-2.16.0-2.el5
zip-2.31-2.el5
zlib-1.2.3-3
zlib-devel-1.2.3-3
zsh-4.2.6-3.el5
Is the 3D mouse connected directly to the machine or are you using an extension or usb hub or something else?
krijnenr
Post by krijnenr »
Problem solved!
The daemon had a non root user id (500) and the sticky bit set. So regardless of the user who started the application it got the non root user permission and hence failed to start!
Hi krijnenr,
I am glad you found the cause for the problem. The sticky bit is not set by the installation nor when we create the installation package. Something must have been messed up. We will keep an eye on it to see if this is related in any way to Red Hat 5.5. Thanks for information.
