Problems on Maya and 3ds Max
fatih.yldrm5
Post by fatih.yldrm5 »
Hello, I am having some problems with maya and 3ds max.
Spacemouse compact is not working with 3ds max 2024.2 at all and with maya problems are bit more complicated.
For maya 2024.2 when I move my camera with spacemouse it losses its focus on object and when I try to rotate with alt + mmb as traditional it doens't rotate around object but rotate around itself(camera). I need to press f each time to re focus and this is not a sustainable workflow.
The bigger problem about maya when I move with spacemouse in a huge scene with many faces it lags after each movement stops. There is no lagging on the scene or when moved with mouse. Only with spacemouse.
I updated to last driver 4/12/2023 but the problems are still there. I am amazed it is not working at all on 3ds max.
