How to disable Cadmouse Radial Menu "fade-in" animation
Julkio
Post by Julkio »
Hello
I am not sure if this has been introduced in the latest driver update or maybe its windows but I do not recall this happening before. So the thing is the Radial Menu that appears when you click the button next to the wheel has a fade-in animation and a fade-out animation. It is just a couple of frames but enough to make it feel sluggish. I need it to be like maya marking menus.
How can I make the opening and the closing of the radial menu instant?
Thank you!
Julkio
Re: How to disable Cadmouse Radial Menu "fade-in" animation
Post by Julkio »
I adding a gif where you can see the issue more clear.
nuntavit
Post by nuntavit »
I second this, it would be great if there's an option to disable the fade in/out of the radial menu, either in gui or in xml.
