Navlib logging configuration?
JoelWilliamson
Post by JoelWilliamson »
In the SDK docs (navlib.pdf), it says
Copy the navlib.xml configuration file to %appdata%\3Dconnexion\3Dxware\Cfg to enable logging.
I can't find a navlib.xml file in either the SDK package or in the folder in appdata. Where is it supposed to be?
Re: Navlib logging configuration?
I noticed that myself a few months ago. As far as I know, it is currently supposed to contain:
<?xml version="1.0" encoding="utf-8"?>
<Navlib>
  <Settings>
    <Logging>
      <GetClient>true</GetClient>
      <SetClient>true</SetClient>
      <ReadValue>true</ReadValue>
      <WriteValue>true</WriteValue>
    </Logging>
    <Probe>true</Probe>
  </Settings>
</Navlib>
JoelWilliamson
Thanks. I'll give that a try.
JoelWilliamson
17:04:16.552: Dumping accessors
	property "coordinateSystem"	fnGet=true	fnPut=false	param=0x0
	property "active"	fnGet=false	fnPut=false	param=0x0
	property "events.keyRelease"	fnGet=false	fnPut=true	param=0x0
	property "settings"	fnGet=false	fnPut=false	param=0x0
17:05:42.315: PutViewPerspective perspective=true
17:05:42.322: PutViewPerspective perspective=true
17:05:42.333: PutViewPerspective perspective=true
MyApp.navlib.log now contains these lines after each start up. Is that all the information I should expect?
JoelWilliamson wrote: Thu Aug 03, 2023 2:09 pm MyApp.navlib.log now contains these lines after each start up. Is that all the information I should expect?
You should also find a "navlib.log" file with additional traces.
