Autodesk Revit
jkk007
Post by jkk007 »
Dace wrote:A colleague of mine is very well connected with the Revit development team at Autodesk, and I heard from him a few weeks ago about 3Dconnexion implementation with Revit. He says: "Also, at AU, I learned that it might be a year or more before the space ball is supported. "
So, while the timing isn't exactly favorable, it's encouraging to know that someone, somewhere at Autodesk might actually be considering a future implementation...
It's a shame that it's taking so long (2 years!!), having the space products work with the Revit family!
sorin
Post by sorin »
this nice blog is always updated with revit's api news.
when the revit programmers finish implementing a viewport api like in other 2d/3d apps (that would make possible to control the view with 3d devices) i'm sure it'll be mentioned there.
http://cadappdev.blogspot.com/
xophe
Revit 2009
Post by xophe »
Hello unpatient users and dear moderator,
Revit 2009 has enhanced API capabilities. 3D devices do not seem to be integrated at the moment but does the API enable 3D connexion to create a plug in?
I am hoping you will.
xophe
kristo
Post by kristo »
two years is a lifetime in computing terms -- all this technology may well be superceded long before then (how about an affordable >60" 3D touch screen -- anyone ?? :-)
in the meanwhile, is it possible to implement these devices via the Windows API or using some sort of scripted commands, rather than natively programming it through the SDK ? that would enable it to work with almost any application surely ?
Revit doesn't have any hooks to allow movement of the scene. They have thought about it, and still are actively talking about it internally. The only way to get them to add some hooks that we can use is to have real Revit customers bug them about it.
It is one of our most highly requested applications. We would be thrilled to have some way at all to make it work. And so would many of their customers.
Jim
3Dx Software Development
Nibster
Post by Nibster »
so, what's the word on this? can we see 3DM support in revit 2010?
I am human, hear me blunder!
It depends on how much you bug them. We've tried...but we aren't customers of theirs. We don't have any pull. Only those who pay have pull.
xophe
Revit 2012: the new hope
Post by xophe »
And then now, after years of waiting...
http://thingsnstuffs.blogspot.com/2011/ ... tures.html
View point 5.
I really DO hope it is coming.
Happy my SpaceNavigator did'nt go out of style in that time :D
Greetings to all happy reviteers.
jun austria
Re: Revit 2012: the new hope
Post by jun austria »
xophe wrote:And then now, after years of waiting...
View point 5.
It's coming and I just cant wait for it to be release.
http://autodesk-revit.blogspot.com/2011 ... -2012.html
Andrey Pavlov
Re: Autodesk Revit
Post by Andrey Pavlov »
It is March 2019 and I confirm, SpaceMouse Wirless DOES'NOT WORK with REVIT 2019 or earlier. It was the biggest dissapointment since the beginning of the year in terms of gadgets. The nice icon appearing in the Revit's interface is not considered a "work". It has problems with orbiting, panning, scaling, etc - NO USE AT ALL. NO respond from Autodesk as well.
I know also that this is not a problem of 3DConnexion, since the same product perfectly works with other software on the same PC. It is a problem of poor collaboration of Autodesk-3DConnexion teams.
Don't waste money if you are an Autodesk user. :x :x :x
Robertoo
Re: Autodesk Revit
Post by Robertoo »
Andrey Pavlov wrote: Tue Mar 12, 2019 9:39 pm It is March 2019 and I confirm, SpaceMouse Wirless DOES'NOT WORK with REVIT 2019 or earlier. It was the biggest dissapointment since the beginning of the year in terms of gadgets. The nice icon appearing in the Revit's interface is not considered a "work". It has problems with orbiting, panning, scaling, etc - NO USE AT ALL. NO respond from Autodesk as well.
is this the solution? for me the Spacemouse works correctly again after I had removed this check mark:
goto; File => Options => Graphics => "view navigation performance" then remove check mark "ALLOW NAVIGATION DURING REDRAW (....)"
I found this trick somewhere on the Autodesk help desk site
(i work with Revit2020)
Alakelele
Re: Autodesk Revit
Post by Alakelele »
Works well for me with that trick, no complaints so far except maybe the zoom in/out feature that works well, almost well
kylesroary
Re: Autodesk Revit
Post by kylesroary »
Autodesk announces significant API changes with the release of the new Revit. Is it known whether or not the SpaceNavigator may be used thanks to the application programming interface?
kslifter
Re: Autodesk Revit
Post by kslifter »
I really hope they make the changes needed for use of this mouse in Revit 2024. I used it in Archicad and Sketchup and loved it. I was so bummed when I switched jobs, made the switch to Revit, and then found out it doesn't work. Honestly it is surprising and odd that a specialty product who use is designed for programs like this doesn't have a better integration.
Alakelele
Re: Autodesk Revit
Post by Alakelele »
It does work, it's just not well implemented. There could be one simple trick that would make things way easier.
The center tool should update automatically when you select an object but you have to do it manually each time, huge burden, make the process automatic and you get a good implementation.
