The sample code to build against the COM control uses #import of an installed driver DLL, located via the Windows Registry (so must be installed.
This only works on a machine which has the 3Dx driver installed... It does not easily support a SVN repository with branches and labelled code points...
How can I properly set up a distributed build environment, where each developer has their own PC and checks out a copy of code from SVN, and builds their private copy, and also there is a headless server environment where "standard" builds are performed in a clean environment.
I need to avoid reliance on every machine having the correct (ie same!!!) driver installed, or even any driver installed. (Note that the majority of build machines do not have a SpacePilot attached, esp. not the headless servers...)
Currently I have hacked the build by taking the .TLH and .TLI files produced by MSDev, and replacing the #import by a #include of the TLH.
Since a COM Interface is supposed to be fixed over time, this ought to work - but is there an approved method?
Distributed build environment?
Creo Imaginem Mente
Hi neil_at_informatix,
The method you described (keep a copy of the TLH) is fine but -- we agree -- not ideal.
I suggest you keep the type library under revision control. You can do this by importing the TDxInput.dll file into a "vendor" folder in your svn repository. You need need to edit the #import line to point to that file.
