Spacemouse Enterprise: Toggle mode, key profile
Re: Spacemouse Enterprise: Toggle mode, key profile
Post by jwick » Mon Apr 03, 2017 3:59 am
Magic Man wrote: Also tried setting a custom lcd brightness setting but that doesn't seem to be supported across config files.
You tried to set
<Device>
  <Name>SpaceMouse Enterprise</Name>
	<Settings>
		<LCDIntensity>5</LCDIntensity>
in AD/global.xml? That works for me. It doesn't work in individual AppCfgs. It isn't something we thought of. I like the idea of having a different background color per app. Are you trying to simulate that with intensity? We animate the cfg switch on the LCD to help show the user that something happened.
Magic Man
Post by Magic Man » Mon Apr 03, 2017 6:03 am
Yep, works in global but tried in individual configs - which it doesn't as you note.
Was hoping to switch the LCD off in global but turn it on only for those applications I have and use a config for.
Yep, noticed the animation of the icon sizes in the .tiff
Post by jwick » Mon Apr 03, 2017 6:09 am
Well that's a new use idea. This is why I like working with you and Phil999. You always have such good ideas.
I think we have some work to do on how we handle non-3D-mouse-supported applications.
Glad to have you back.
Magic Man
Post by Magic Man » Mon Apr 03, 2017 6:25 am
:D
Phil999
Post by Phil999 » Mon Apr 03, 2017 1:37 pm
glad as well, although I cannot contribute as much as I would like to.
RNowak
Post by RNowak » Fri May 19, 2017 12:20 am
great work from "Phil999"! Thanks!
Got this product but not having option to change profile did me angry. Thanks to You got it somehow working for Autocad and Revit.
Not sure why I have to start driver after firing Autocad to make mine profiles properly viewed on LCD. When driver is already running profiles are switching but the LCD shows only Default value. I think it has sth to do with the driver maybe. But this way I can manually change profiles. Is is big shame that driver has no such functionality out of the box.
AxeGunKnife
Post by AxeGunKnife » Thu Aug 17, 2017 8:13 am
jwick wrote: ....
... I wrote a tool for creating, managing ButtonBanks. I can clean that up and distribute it if needed. In the meantime, notepad++ is your friend.
:shock: Please.. please ... please ... please!!! :D Give me this amazing tool! :wink: ... Notepade++ is not my friend, unfortunately :(
Thx.
AxeGunKnife
Post by AxeGunKnife » Thu May 03, 2018 10:40 pm
Guys! When you are already implementing normal editing of the radial menu with icons and text ???? !!!!! What is the problem?????
