If you have problems getting Blender NDOF run with your space navigator,
download the vcredist.exe (2.6 MB) from Microsoft homepage (The MS Visual C++ Redistributable 2005) and install it.
That solves the "ndofLib=0000000" problem !!!!!
Now my space navigator is detected when starting blender and the navigator works perfect now!
However, make sure that the mouse pointer is over the 3D Window, otherwise it will not work. I had to reconfigure the buttons and axis of the navigator also (e.g. invert axis and increase speed and the like). Once you are satisfied, save the configuration e.g. as "Blender".
This process was a little bit confusing, but finally worked.
Hope that helps.
SOLUTION for Problems with space navigator and Blender WinXP
