Hi there,
I have been trying to use your SpaceNavigator for Revit, to use it for the walk mode, and it works really great! But then i hoped i could use the same function when I exportet my 3D views to Autodesk Design Review in the DWF format, since its basicly the same company who makes the two programs.
But sadly you dont get the same option to use the "SpaceNavigator walk mode" as you do in Revit... and when using the SpaceNavigator in Design Review, it doesnt stick to the axis as it does in Revit.
Is this something you could have a look at? Because it would really be helpful if you could walk around in your 3D .DWF files just like you do in Revit, using your SpaceNavigator.
Regards,
Jens Majdal Kaarsholm
Autodesk Design Review - Walk Mode
Re: Autodesk Design Review - Walk Mode
Hello Kaarsholm,
the support for the 3D mouse in Autodesk Design Review was implemented by Autodesk. This feature can only be implemented by Autodesk. Please address this feature request with their support team.
