More specific I can't uninstall my drivers, because the uninstall tries to find some files in the local settings / temp folder which have been removed.
I have driver version 5.9.2 and a spaceball 5000 usb
can't upgrade drivers
If you go to the following Website
http://support.microsoft.com/default.as ... -us;290301
Download the Windows Installer Cleanup tool.
Run the tool and look for anything with a [] bracket
select and allow the cleanup tool to remove it .
Otherwise if you see 3Dconnexion click on that and it will remove the registry entries.
Fred
Fred
Fixed
Yes! Thank you, it worked perfectly.
Jeroen
Jeroen
