One labtop with two controllers
leifnebel
Post by leifnebel »
Hi
At work I am using a Spacemouse Plus Serial and at home I have a Spaceexplorer USB. These controllers have different drivers and I hoped they could run on the same labtop.
At the moment I am installing the driver each time I need to work at home. Does anyone have any experience in these matters?
I hope there is an easier solution.
Best regards
Leif
Hi Leif,
Yes, you are stuck in a rough spot because there is no one driver that supports an old device and the new devices.
You may be able to have both installed at one time in two different directories and start which ever driver you need. You'll have to fix up the 3DxWare registry entries, but that can be done with a .reg file.
3Dx Software Development
