Brush size not working - Shortcut pop-up keeps appearing
selphet
Post by selphet »
I am not able to get the brush size function working. I tried to run Photoshop as Admin, but no luck.
The strange thing is, that even after I change the shortcut for 3dxPhotoshop, the pop-up keeps appearing. When I check the shortcut is still there.
When I try to rotate the button, I get the double arrows for duplicating like when you would press Alt with the move tool.
Because of all this and no clear answer in the forum about this, dispite the fact that a lot of people have problems with it. I think this is a driver or plugin issue.
So please advice on this!!!
