Hey there,
Am using Maya 2015 and there's a bug that's been driving me nuts. For some reason when you have a group node selected (and generally you have a tonne of these in a scene) the rotation center is offset by quite a distance from the actual group pivot, this causes you to be rotating around a random point in space as opposed to the group that you want to be focused on. Have tried experimenting with having 'Auto' and 'Use Selected Item' on and off but its the same. Also the further away from the origin you move the group, the worse the offset is. This is a very easily reproducible bug but one that's prevalent in complex scenes, please fix!
Cheers
Alex
Maya rotation center issue with group nodes
