New Navigator PE doesnt work
Hans
Post by Hans »
i connected my new space navigator to the pc, download and install the software.
but nothing happens... When i "Start Driver" i can see the 3DxSrv.exe for only 1second in the taskmanager. the same on "Show Control Panel".
the Cube3d Demo says "Can'T find a 3d motion controller" . the other demos doesn't start.
i disconnected all other usb devices and try out all ports (usb2.0)..
system: windows xp pro sp2
Hans
Post by Hans »
the logfile:
22:50:29.093: 3DxWare driver startup: 4/26/2007 22:50:29
22:50:29.093: 3DxWare Driver Version 6.2.1 : March 15, 2007
22:50:29.093: -quiet -- disabled
22:50:29.093: -shutdown -- disabled
22:50:29.093: -protocol -- none given. All protocols enabled.
22:50:29.093: -com -- Disabled, using spcware.ini file settings.
22:50:29.093: -dev -- Disabled, using spcware.ini settings.
22:50:29.093: -eps disabled sending each event.
22:50:29.093: -log enabled
22:50:29.093: -logLevel ffffffff
22:50:29.093: -logFile C:\3DxWare.log
22:50:29.093: -searchWarnDlg not enabled
22:50:29.093: -showGUI not enabled
22:50:29.093: -hideGUI not enabled
22:50:29.093: UdCtl: Attempting to find (ID=1031) 'German' locale in DE_DE
22:50:29.093: UdCtl: Found resource DLL in C:\Programme\3Dconnexion\3DxWare\DE_DE\3dxsrv.dll
22:50:29.093: UdCtl: initialization successful.
22:50:29.093: UdCtl: Attempting to open Beliebiges Gerät (-1) on USB.
22:50:29.093: UdCtl: Attempting to load device DLL: C:\Programme\3Dconnexion\3DxWare\UdDev\HIDDev.dll
22:50:29.109: UdDev: Attempting to open 3Dx-supported HID device on USB
22:50:29.125: UdCtl: Unable to open Beliebiges Gerät (-1) on USB.
Absum
Post by Absum »
What is "Beliebiges Gerät"?
Hans
Post by Hans »
its german for "any device" or "general device" "unspecified device" .. dont know whats in english windows
Hi Hans,
It seems that your device is not being recognised by the system. Are you using a USB hub? Is the device connect directly to the machine?
Hans
Post by Hans »
no hub. directly to the usb on board. all other device works with it (sanner, ubs stick, iPod..)
agoenczi
User
User
Post by agoenczi »
Hi Hans
To be sure if your device isn't defective please test it on another computer without other USB devices connected to it. You have to install 3DxSoftware and to connect the device. Afterwards try to use one of the supplied demos (Start -> All Programs -> 3Dconnexion -> 3Dconnexion 3DxWare -> Demos).
If it works, please try to connect your device via an USB hub with own power supply to the computer you normally use. You have already some devices (as you described) connected and it could be that the USB power reached the limit and that's why you device doesn't work.
agoenczi
Hans
Post by Hans »
its the same on my other (old) computer.
i tried it with no other usb device connected..
agoenczi
User
User
Post by agoenczi »
Hi Hans
That seems to be a hardware problem. Please contact the support of our company. You will find contact information here.
agoenczi
