3d mouse Soilidworks-Auto rotation center not working
tattoo
Post by tattoo »
sometimes the auto rotation center in solidworks doesnt work
and often the object is moving without me touching the 3dmouse....
it is checked in properties and everything seems ok, but it still does not always work....
Bryan
Re: 3d mouse Soilidworks-Auto rotation center not working
Post by Bryan »
Dear tattoo,
You may need to re-zero your device.
Start
All Programs
3Dconnexion Control Panel
Device Configuration Tab
Calibrate Button
Sincerely,
Bryan
abqsteve
Post by abqsteve »
tattoo wrote:sometimes the auto rotation center in solidworks doesnt work
I'm having the same trouble where the auto rotation center does not work in Solidworks 2013 SP4.0. Any hints on how to get it working?
Fred
Post by Fred »
It is possibly caused by data corruption. You can use "Restore all Defaults" in your SolidWorks profile to return to default settings. [3Dconnexion Control Panel – Options- Restore all Defaults] There may be multiple SolidWorks profiles. You can use Options- Delete Saved Configurations to remove the SolidWorks profiles.
abqsteve
Post by abqsteve »
Thanks Fred! I did both those things and the auto rotation center is now working.
maxtkirk
Post by maxtkirk »
For me remain the same problem. On solidworks 2013 sp3 the mouse pan and zoom only. Rotation doesn't work.
On other cad the mouse work well.
I do calibration and reset settings.
Some help?
Hello maxtkirk,
which driver version do you use?
