Hi
I am using the SpaceTraveler inside 3D studio Max (7 and 9), it works fine when I have max open on one monitor but when I span it across two/dual monitors The navigation slows down far to much.
I am running max in OpenGL mode with an ATI FireGL V7350 on XP 32bit.
Any suggestions for a cure?
Regards Rueben
slow dual monitor response in Max
Hi ruebenad
Please specify: is the navigation with the mouse slower as well?
Which types of monitors do you have attached to your PC?
Do you span your 3ds max window across the two monitors?
agoenczi
