Is it possible to disable automatic recalibration from the XML config?
MarinHobin
Post by MarinHobin »
I was wondering if it is possible to disable the automatic recalibration that gets triggered by holding the device off-center for a set period of time, by setting some sort of flag in the XML-files for each executable?
Right now when it gets triggered unexpectedly and it is quite a pain.
Cheers,
Marin
Re: Is it possible to disable automatic recalibration from the XML config?
Hello Marin,
There is not an XML element for controlling this feature. It's not a bad idea through.
I can send you an executable to turn it off. You have to run it every time the device reboots. It will turn it on when it restarts.
What device type do you have?
Jim
3Dx Software Dev
MarinHobin
Thanks for the response. I've a SpaceMouse Compact.
Marin
PM sent
