3dsmax2019 cameramode switch randomly to target mode
Re: 3dsmax2019 cameramode switch randomly to target mode
thanks for the support
could i have acces to a beta release of the driver?
one more thing, if you are gonna change the driver, ther are one issue and one feature we got worse in the last driver:
1 random navigation switch between camera and target mode (as described previously)
2 the radius of rotation:
in 3dsmax2015 movement speed depended on the target distance of the selected camera or the perspective radio distance
in 3dsmax2019 movement speed is fixed and independent on the target distance
i do appreciate to have it back to the speed depending on the camera or perspective radio
I would like to throw in my vote for bringing back the old navigation speed algorithm.
Or at least to be able to select it in the setting from the two: world center and focus distance.
Actually each of them might be useful, but there are different projects with different scales and objects counts.
I doubt it's an advancement as it is right now. It would be so if there would be an option to leave the old way of working through options.
Thanks for your hard work on bringing it all together!
ngomes: Could you plz report if the issue regarding the camera speed not being proportional to the target distance (either through viewport camera or perspective mode) is being worked and included in the next update? As InfArq described, there are 2 issues that need to be addressed to make spacemouse usable in 3ds max 2019. One of which you have confirmed as being resolved for next driver update.
thnak you very much!!!!!!!!
it's working finally!!!!!
thanks for the support...!!
for me 3dconnexion is a must tool for the 100% of the day to place cameras on VFX scenes so... thank you so much!!!
We were waiting to have the fix validated using a pre-release build of our 10.6.6 software. It looks like the issue with camera speed has also been addressed.clearskystudio wrote: ↑Mon Apr 06, 2020 8:58 am I would like to throw in my vote for bringing back the old navigation speed algorithm.
Great to hear, can I also have a pre-release version of the driver?
Hi thempus,
We ask you to please wait until then since we cannot begin to send the pre-release code on a one-to-one basis.
We're aiming to release the software very soon and before the end of next week (April 17th).
Updated the driver and nothing that was discussed seem to be fixed on 3ds max 2020. It clearly shows the new driver "10.6.6" as the latest, also it had the "3ds max plugins" checked during installation. Hardware will remain worthless meanwhile.
Thanks for fixing this! It's been driving me crazy!
When will you fix this?? We have around 40 spacemouses that I'm tempted to shrow in the trash. This is a nightmarengomes wrote: ↑Fri Apr 03, 2020 10:39 amThis appears to be the WIN-620 issue. We believe to have it fixed in the 10.6.6 release and we're now seeking to have it verified.
I just wanted to make sure there there was nothing else we were missing.
I'm sorry for causing further confusion rather than helping to clear it up.
Since you linked to the WIN-620 discussion, you may be referring to the navigation mode switch to "target camera".
The switch is by design: if the view is orthogonal, a camera cannot move around the scene. In other words, "moving around" a scene requires the view to be set to perspective. If the view is non-rotatable, then the SpaceMouse can pan and zoom the scene.
If you wish to confirm, check the view properties and confirm the view is set to perspective. If you are running a command that switches the view from perspective to orthogonal and then you touch the SpaceMouse, then the navigation mode will switch automatically to "target camera".
