3dConnection Enterprise random drifting in every axis
ultek
Re: 3dConnection Enterprise random drifting in every axis
Post by ultek » Sat Oct 26, 2019 10:44 am
jwick wrote:
Fri Oct 25, 2019 1:12 pm
We ship a program called "3DxTest" in the 3DxWinCore installation directory. Run that and tell me what you see. You should see values from the 6 axes. Is one of the more active than the others.
Hey jwick, below are values from 3dxTest:
TX: stable 0
TY: from -59 to -50 with peaks above -40 every couple of seconds
TZ: from -75 to -70 with peak above -55
RX: from 90 to 110 with peaks belov 90
RY: stable 0
RZ: from -60 to -40
P: stable 16
Then, as tech support suggested, you can calibrate it using the shortcut in the 3Dx systray icon. That should settle down the values printed in 3DxTest to all zeros when you release the cap.
Unfortunately calibrating doesn't help with anything. The drift is extremely heavy. After calibrating 3dxTest shows the same values as above.
Does the device rattle when you shake it or other obvious physical problem?
Nope. Only rattle is from buttons which can be neglected when shaking while holding them. The device stops working suddenly which was kinda weird.
ultek
Post by ultek » Fri Nov 01, 2019 7:10 am
I got a response from Polish support team. Despite their best intentions they were unable to help.
Looks like my experience with spaceMouse ends at this point. :(
Post by luping » Fri Nov 01, 2019 6:27 pm
You can invest on a new device, the 3D mouse should worth the money you invested, and you get a high return of investment: reduced future medical expense for your fingers/hands and higher productivity.
ultek
Post by ultek » Mon Nov 04, 2019 12:34 pm
Hey It's me again :)
So today I took me spacemouse and with nothing to loose I sprayed the joy and everything beneath it with dry-erase cleaner (I think it's 100% alcohol). Then I wrapped it in foil and left for about 15 minutes. After this the device is working like a charm (for a couple of hours now), no more drifting and 3dxtest shows 0 on every axis and "zero event" at the top of the window. Not sure how this procedure helped but it helped :) Or maybe it's just a coincidence? 8)
Best.
ult.
Post by jwick » Tue Nov 05, 2019 3:40 am
Interesting. Wouldn't have been my first choice of liquid but it was probably convenient.
You had dirt or corrosion on some your LEDs or PSDs?
I'll run it by the hardware guys next time I see them.
Post by luping » Tue Nov 05, 2019 9:05 pm
Best.
ult.
Amazing, it's like WD-40 specialist electrical contact cleaner spray. I like your think out of box approach. :D
