uludwig wrote:3DxWare.log wrote:...
9:6:43.828: UdCtl: Attempting to open Any Device (-1) on USB.
9:6:43.828: UdCtl: Attempting to load device DLL: C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdDev\HIDDev.dll
9:6:43.828: UdCtl: Could not load device DLL HIDDev.dll. Error=0x1e7.
9:6:43.828: UdCtl: Unable to open Any Device (-1) on USB.
Terry,
the error from the 3DxWare.log shows that you have the same problem as another user in the forum. In his case it was the BitDefender Antivirus software that blocked the driver. See
here for his post.
Hi Uta,
Made an exclusion path in BitDefender 2010 for the whole of the 3Dconnexions folder on 22 October but this did not work. Have, yet again, tried an unistall and install but to no avail. Log File follows:
8:25:0.843: 3DxWare driver startup: 11/10/2010 8:25:0
8:25:0.843: 3DxWare Driver Version 6.11.1 : July 30, 2010
8:25:0.843: -quiet -- disabled
8:25:0.843: -shutdown -- disabled
8:25:0.843: -protocol -- none given. All protocols enabled.
8:25:0.843: -com -- Disabled, using spcware.ini file settings.
8:25:0.843: -dev -- Disabled, using spcware.ini settings.
8:25:0.859: -eps disabled sending each event.
8:25:0.859: -log enabled
8:25:0.859: -logLevel ffffffff
8:25:0.859: -logFile C:\Documents and Settings\User\Application Data\3Dconnexion\3DxWare\3DxWare.log
8:25:0.859: -searchWarnDlg not enabled
8:25:0.859: -showGUI not enabled
8:25:0.859: -hideGUI not enabled
8:25:0.859: UdCtl: Attempting to find (ID=2057) 'English' locale in EN_GB
8:25:0.859: UdCtl: Found resource DLL in C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\en_us\3DxSrv.dll
8:25:0.875: UdCtl: initialization successful.
8:25:0.937: UdCtl: Attempting to open Any Device (-1) on USB.
8:25:0.953: UdCtl: Attempting to load device DLL: C:\Program Files\3Dconnexion\3Dconnexion 3DxSoftware\3DxWare\UdDev\HIDDev.dll
8:25:0.953: UdCtl: Could not load device DLL HIDDev.dll. Error=0x1e7.
8:25:0.953: UdCtl: Unable to open Any Device (-1) on USB.
As you see still the same.,
Yours frustratedly,
Terry
