Hello Forum, I have a problem, I use 2 3d connexion devices, both wireless with the universal usb connector. When I plug a usb memory stick into my machine it seems to break the connection to my devices, they basically don't work, at all. As soon as I eject the pen drive they return to normal use, clearly some sort of bug/error ?? Or is there any setting I need to change so they don't conflict ? tia
wireless space mouse
wireless cadmouse pro
windows 10
USB Memory Stick Breaks Connection To Devices
Re: USB Memory Stick Breaks Connection To Devices
Is your USB memory stick connected to an USB 3.0 port of your computer where your 3Dconnexion Universal Receiver is also plugged into another USB port next to it? If so, there may be some kind of electromagnetical interference, try plug the USB memory stick to an USB extension cable to eliminate the interference or plug the 3Dconnexion Universal Receiver to an USB extension cable to eliminate the interference.
yep, that seems to be the problem, have now inserted my universal usb receiver into the back of the machine, this solves the problem
