Cadmouse wireless polling rate
Cristian
Post by Cristian » Sun May 19, 2019 9:05 pm
Hello everyone, my first post on the forum
I've been using the wireless cadmouse for a few months now. I'm having an issue with the low polling rate of the mouse when it is conected via the wireless adapter ( around 250 MHz) . When I'm drafting in 2D and I try to do fast moves, the mouse lags . Is there a way to set the polling rate higher , like when the mouse is connected via the USB cable (500-1000 MHz), even if the battery life will be shortened !
PS. I'm using Windows 10, latest drivers and the USB dongle is very close to the mouse, around 60 cm.
aalsalihi
Re: Cadmouse wireless polling rate
Post by aalsalihi » Mon May 20, 2019 7:24 am
Hi Cristian,
You could change the polling rate by following these steps:
- Open 3Dconnexion Home
- Make sure the device is selected on top
- Click on Advanced Settings
- Changed the Sensor Polling Rate
That's how you could switch the polling rate for the CadMouse or any other 3DMouse
Abdul. A
Cristian
Post by Cristian » Mon May 20, 2019 10:31 am
Hi Abdul,
Thanx for the response but it only works for wired mode ! they need to change this in the next release of 3DxWare .
aalsalihi
Post by aalsalihi » Mon May 20, 2019 11:31 am
Hi Cristian,
Thanks for your respond, we'll definitely let the team know.
Abdul. A
Post by UtaSH » Mon May 27, 2019 2:54 am
Hi Cristian,
when connected with the receiver the polling rate is limited to 125 Hz due to technical reasons. The higher rates are available only when the device is connected with the cable to the computer.
