Solid EDGE Issues
psandherr
Solid EDGE Issues
Post by psandherr » Mon Apr 29, 2019 6:31 pm
#-D mouse will not work with solid edge, if i click the side buttons it will pull up the radial menu but it will not manipulate a model. The demo works.
Is there a plug in or Add-in i cant find that im missing?
All drivers are up to date
aalsalihi
Re: Solid EDGE Issues
Post by aalsalihi » Thu May 02, 2019 5:26 am
Hi Psandherr,
If the SpaceMouse is working with the 3Dconnexion viewer then the issue might be with the plugin. Can you please run the installer again and choose modify then check if the plugin for Solidedge is Enabled or checked then proceed after.
You could also check Siemens forum post regarding the same issue here: https://community.plm.automation.siemen ... td-p/30704
Please provide some feedback if the issue still persist.
Abdul. A
