Hi Ferelcabeza,
What version of Lumion are you running?
I would recommend that you request for 3D mouse support in Lumion at Act-3D B.V.
Can you please try this workaround that would ignore an application? Let me know if that works for you.
- Remove the Lumion.xml file you have in “…\AppData\Roaming\3Dconnexion\3DxWare\Cfg”
Here's an example of what mine looks like before. This is where you'd replace with the code below:
- 2019-05-02_11h39_03.png (9.11 KiB) Viewed 4406 times
3DxHome and a few other applications have Cfgs that tell the driver to ignore them:
<CfgProperties>
<Access>
<ReadOnly>true</ReadOnly>
<Hidden>true</Hidden>
<Ignore>true</Ignore>
</Access>
</CfgProperties>
- Get our latest version of the driver 10.5.6 available here:
https://www.3dconnexion.fr/service/drivers.html
- Place the Lumion.xml in attachment into the “…\AppData\Roaming\3Dconnexion\3DxWare\Cfg”
- Reboot the computer
- Make sure the driver is started
- Start Lumion and do your testing
Thank you,
Nia
